Dash light don't work
Old Feb 9, 2012 | 08:39 PM
boostedmax305's Avatar
I was putting a new radio in my max and then when I went to turn on the car the dash lights didn't turn on so now at night it's hard to see my rpms and speedometer. Plz help me ASAP thanks
Old Feb 9, 2012 | 08:43 PM
T_Behr904's Avatar
Did you double check all of your connections?
By all means, don't take this the wrong way, but did you check your dimmer switch to make sure you didn't brush against it and turn the brightness down? I've actually done that myself a time or two.
Old Feb 9, 2012 | 08:45 PM
Quickywd01's Avatar
You could have blown a fuse. Look under the driver side dash for the fuse box and check.
Old Feb 9, 2012 | 08:50 PM
I look at the fuses they all look fine and all my boost gauges work perfectly and the little digital clock and the lighter socket idk what it can be
Old Feb 9, 2012 | 10:07 PM
Jason1979a's Avatar
Does your radio stay working when you turn the lights on? Just asking. The maximas we drive have no ground wire in the dash for the radio. They ground through the chassis of the radio and the radio brackets. The reason i bring this up is because the Dash light wire (also called a illumination wire or dimmer wire) reads a ground till you turn on the lights. So if your used the Dash light wire for a ground, It will cause your dash light to quit working. There is still probably a blown fuse. Don't forget to check under the hood for fuses. I hope this helps.
Old Feb 10, 2012 | 05:48 AM
I'll check up after school and let you guys know
Old Feb 10, 2012 | 11:46 AM
moNYtx's Avatar
You may have wires touching. Make sure you are capping the ends of the wires properly. You says you checked fuses and they are fine so, check your ground and make sure it has good contact.
Old Feb 13, 2012 | 06:22 AM
cashoit's Avatar
This.
I have done the same to my max when installing a radio. Make sure that u tape off all unconnected wires or it will touch some metal behind the radio and make a short.
Most likely u didnt tape off the dimmer (yellow) wire.
Old Feb 28, 2012 | 03:55 PM
ebrown382's Avatar
My 97 maxima's doing the same thing. I installed a radio and the lights were still working fine. Then, one day a neighbor used a tester tool to check that all the connections were good and that night, my gauge and PRND lights don't work. I know a tester couldn't have done anything but its too coincidental that they stopped working that same night after he tested the wires under the hood. Any idea why?
Old Feb 28, 2012 | 04:15 PM
tigersharkdude's Avatar
did you check your fuses ?
Old Feb 28, 2012 | 04:35 PM
ebrown382's Avatar
Yes they're all still good.
Roymg
Sep 3, 2018 05:10 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
