How come the max feels fastrer when...
Old Jan 2, 2002 | 04:50 PM
Kevlo911's Avatar
Kevlo for President
when u push the gas when its moving with the rpms then just pushing it to WOT
Old Jan 2, 2002 | 05:04 PM
Micah95GLE's Avatar
Can you rephrase the question? I don't understand.
Old Jan 2, 2002 | 05:38 PM
MAXIPADMAN's Avatar
uhh, ...we no exprickizee espanglish !
Old Jan 2, 2002 | 05:41 PM
Vyrus's Avatar
I think he means...
How come the car feels faster at close-to-full-throttle rather than at full-throttle. Am I right?
-Cyrus
Old Jan 2, 2002 | 06:08 PM
nixima's Avatar
I think he meant that the car appears to be faster when the gas pedal is pressed gradually, as the rpm rises, rather than wide-open throttle.
Old Jan 2, 2002 | 06:22 PM
phatmax95's Avatar
yeah i belive thats what he means, i had the same question.. look here:
http://forums.maxima.org/showthread....threadid=79907
Old Jan 2, 2002 | 07:23 PM
Kevlo911's Avatar
Kevlo for President
ya that is it......sorry
BTW link doesn't tell much
Old Jan 3, 2002 | 07:59 AM
chris j vurnis's Avatar
It is all dependent of flow velocity at various RPMs. AIR VELOCITY is what generates good intake power and therefore more horsepower potential.
With the throttle partially closes, a smaller volume but higher velocity of air can get into the intake runners.
Here is a good analogy: Take a garden hose with a gentle stream of water and then put your finger over part of the opening... the water suddenly leaves the hose with higher velocity.
Also depends whether its an automatic or manual tranny.
Dumping a lot of power into the automatic tranny off the line just makes the converter slip at wide ratios which rapidly builds up heat. The stall speed might be around 3000RPMs and will hold those RPMs until the road speed catches up. Unfortunately, the wider the slip ratio, the lower the mechanical efficiency.
So therefore, flooring the accelerator in an automatic doesn't do any good and actually slows down the initial acceleration.
Old Jan 3, 2002 | 08:24 AM
Synki's Avatar
Very well put.
The car def reacts way better when you gradually press teh gas vs just going right to WOT. This is the technique i use on stree & drag strip.
Old Jan 3, 2002 | 09:42 AM
gtr_rider's Avatar
192.168.1.1
I noticed this many times, the car sounds nice and mean when you do the 3/4 throttle to me. I was wondering what happened when he took off from a roll and I waited a second before I caught some air. BTW, would this type of technique help with a hot air Intake?
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
ik95
Sep 16, 2015 08:11 PM
