Tranny Acting up
Old Feb 21, 2012 | 07:04 PM
GeorgeTown's Avatar
Tranny Acting up
Hey All . . . Its been a while
Well I have a 96 SE Automatic and all of a sudden I have a problem wih the tranny starting off in second gear or something like that.
What happens is . . I put the tranny in drive and when I press the gas it takes off real slow like as if it is starting off in 2nd gear and not first gear. But then you turn off the car and start it then it goes away until you press on the brake again
Anybody ever ran into this before?
Old Feb 21, 2012 | 07:09 PM
maxed_out_99's Avatar
first i have a few questions for you
how many miles are currently on your trans
what does the fluid look like
has it ever been spill and filled or flushed
any codes or ses light
Old Feb 21, 2012 | 07:12 PM
GeorgeTown's Avatar
Around 200k
Fluid looks good
Never flushed
No codes
Old Feb 21, 2012 | 07:28 PM
if theres no codes it may not be a solenoid related issue that doesnt rule it out though.
your valve body my have some crap in it i suggest dropping the pan and replacing the screen and pan gasket. if a nut on the screen just "spins" i hate to say it but you have to remove the valvebody but we will cross that bridge when we get to it. make sure you clean the pan really well and clean up those magnets. if you drop the pan do not freak out the magnets are probably like furry little animals. thats normal. fill the trans with nissan D matic only these transmissions are picky to what kind of fluid they use see if that solves your issue
when its acting up if you hammer it does it downshift
Old Feb 21, 2012 | 07:37 PM
GeorgeTown's Avatar
WHen I floor the gas it just stays in the gear it is in
Almost felt like the e-brake was on
Old Feb 22, 2012 | 09:46 AM
rf97's Avatar
I too have this same problem, car starting off as if in 2nd gear and not shifting, my OD light not coming on, my abs, brake light, battery charge lights are all on. All these issues started after my battery went totally dead, could this have caused this problem, ie computer needs to reset?. Not trying to hijack this thread, but since I have this same issue figured I would piggy back.
Old Feb 22, 2012 | 11:38 AM
Start by replacing your battery remember you hav an electronically co trolled transmission if you don't have the juice you could have all sorts o issues
Old Feb 22, 2012 | 11:39 AM
What happens when you manually engage 1st
Old Feb 22, 2012 | 02:24 PM
asand1's Avatar
my abs, brake light, battery charge lights are all on. All these issues started after my battery went totally dead, .
All symptoms of a dead alternator. Are you charging? In your case it may be a low voltage issue. Have the Alt checked under load.
Old Feb 22, 2012 | 08:02 PM
rf97's Avatar
You might be on to something here, after installed a new battery still under warranty I started the car, then I remove the positive cable with car still running as I wanted to see if the alternator was charging, the car stayed on but ram very rough couldn't even accelerate. Could this mean I need a new alternator, also could the fact that I disconnect the pos. Cable caused the issue the Tranny issue
Old Feb 22, 2012 | 08:08 PM
rf97's Avatar
You might be on to something here, after I installed new battery still under warranty I started the car, then I remove the positive cable with car still running as I wanted to see if the alternator was charging, the car stayed on but ram very rough couldn't even accelerate. Could this mean I need a new alternator, also could the fact that I disconnect the pos. Cable caused the issue the Tranny issue
Old Feb 22, 2012 | 10:11 PM
TravisCadello's Avatar
ITS The Tranny going into safe mode it stays locked into 3rd gear and wont leave 3rd till off and back on. theirs a tranny sensor out. not really anything internal. take to tranny shop have it checked out.
HOKUSMAX
Nov 13, 2017 04:34 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
zmcneely13
Sep 26, 2015 02:26 PM
pktaske
Sep 4, 2015 08:40 AM
