Can you replace a headlight/ballast on a 7th gen without removing the wheel?
It's been 2 years since I installed them, and it looks like I'll need to replace a dead ballast. I mounted the ones for the headlights on the very commonly used "shelf" that you can access by removing the wheel wells. I remember taking off the wheels to get in there. Is that definitely necessary? Or would I spend more time not having enough room than I'd spend if I just jacked up the car and took off the wheel?
If you turn the wheels all the way to the right and start on the left wheel well, You're able to pull out the clips and reach in through the wheel well without taking off the wheel. I think The shelf everyone refers to is the metal tab that holds one of the clips for the wheel well in so it should be right on front of you. It's a tight squeeze but i was also able to reach up and change the bulb. I did my entire hid install this way.
03VQMAX
Sep 25, 2015 04:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
