Idle problem with burnt gas smell, need help!
Old Mar 8, 2012 | 01:11 AM
a33i30's Avatar
Hey guys, I did some research on my car's problem but I'm still not sure what it is. The car is a 01 I30 with 53k miles, and a couple weeks ago it had a moment where the idle would jump from 1300-1700 and wouldn't idle normally. After reseting the ECU it went away.
So today, as I was driving, the car completely turned off, after that it would stall if I didn't give it gas when starting, so I left the car for 5 minutes and when I came back it started up just fine but the interior smelled like burnt gasoline (sort of like burnt clutch smell). The car would also not drop the idle any lower than 1000 rpms, even when the engine was warm. Anyways, I left the car and when I went back to check up on it at night, it smelled like burnt gas/clutch type of smell again, and it was only the interior that smelled, the engine bay didn't. I just decided to disconnect the battery because it felt like it got worse as I left it there.
Can anyone help me with this? I thought it might something ignition related but that wouldn't explain the burnt smell comming from only the interior..
Old Mar 8, 2012 | 08:29 AM
Xpcgamer's Avatar
Does it smell like rotten eggs. May be clogged cats?
Old Mar 8, 2012 | 09:31 AM
DennisMik's Avatar
It sounds like you have a bad IACV that shorted out the ECU.
Old Mar 8, 2012 | 04:30 PM
a33i30's Avatar
Ah, do you think cleaning it will help? Or should I just replace it?
Old Mar 9, 2012 | 12:19 AM
mycarssilver55's Avatar
I had the same issue with a rough idle and gas smell in december, turned out to be a busted flex pipe, I'd check the exhaust line for leaks just in case.
Old Mar 9, 2012 | 10:22 AM
DennisMik's Avatar
If my prediction of doom and gloom is correct, parts must be replaced or repaired. The IACV gets replaced and you send the ECU out for repairs.
This is what may have happened inside the ECU. That could be what you spelled inside the car.
Old Mar 9, 2012 | 03:13 PM
a33i30's Avatar
I think it did burn my ECU. Would you recommend a place where I can send it in for repairs or get a new one? Also how does the ECU get out of it's place? I just took the cover off and it smells pretty bad from there, the car was also not keeping idle when I started it.
Old Mar 9, 2012 | 07:53 PM
DennisMik's Avatar
I've never pulled my ECU out, so I can't help you there. But here is a link from a few days ago about getting one repaired.
http://forums.maxima.org/5th-generat...ip-repair.html
In this thread is a link to another long, long thread about burning up ECUs.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
97_GXE
20
Sep 17, 2015 08:12 PM
slowlifer
Sep 8, 2015 05:53 AM
