Oiled air filters and maf problems survey
Old Mar 15, 2012 | 04:19 PM
slowmanvns's Avatar
How many persons have had issues with their maf after using oiled air filters. I am beginning to think this as being the cause for my stalling problems. I did a search and found too many coincidences.
Old Mar 15, 2012 | 05:06 PM
It's definitely a possibility. After having an oiled K&N, then having MAF issues, I cleaned the MAF (which had the redish oil on it) and switched to a dry flow Amsoil and haven't had issues since.
Try giving you MAF a cleaning.
Old Mar 15, 2012 | 05:40 PM
ShocknAwe's Avatar
Maybe you used to much oil? are you supposed to wait a specified time before driving with it? Ive never had this problem before
Old Mar 15, 2012 | 06:27 PM
slowmanvns's Avatar
I've never re-oiled mine, but then again it's been it there for more than a few years ...it always looks very clean so I've never changed it - fram airhog. Maybe it dried up so much it started to flake off and damaged maf...my fault I guess..
Old Mar 15, 2012 | 06:50 PM
Gismo-T's Avatar
B!tch We Got a Problem
Yes, you're supposed to let it dry before putting it back. The screen on my MAF had oil residue from not letting it dry long enough.
Old Mar 15, 2012 | 06:53 PM
ShocknAwe's Avatar
I use a dry anyways just so I don't have to mess with it but the waiting seems obvious to me. Probably takes awhile to fully absorb throughout the fibers
Old Mar 15, 2012 | 07:40 PM
infinimax96's Avatar
I bought my car with a specter oil cone filter. I used the k/n filter cleaner as directed and even let it dry overnight before driving the car. Inevitably I'd still find oil residue on the inside of the maf housing. Even when i used very little oil i would still find residue after 3000 miles.
I just recently bought a dryflow 80mm Apexi power intake filter. I'll never look back to an oil filter again. Not only is the dryflow worry free but it also comes with a nice velocity stack inside the filter.
Old Mar 15, 2012 | 07:49 PM
dannyperrault's Avatar
yeah i work at a advance and i get like 2 comes a day complaining about maf issues after cleaning there k&n filter, i think they had a very poor design. i found out its more comon on ppl who do highway driving frequently
Old Mar 15, 2012 | 08:16 PM
It doesn't surprise me. What's annoying is if you have an oil based air filter you have to use the oil. Otherwise it won't filter properly. That's why I finally ditched it for the apexi. I was sick of having to constantly clean my maf every time I cleaned the filter.
Old Mar 16, 2012 | 04:11 AM
CMax03's Avatar
I switched too Dryflow filters yrs back since oil could cause premature failure of your MAF sensor!
Old Mar 16, 2012 | 05:42 AM
njmaxseltd's Avatar
Over 130,000 on the k&n many cleanings, no MAF issues.
Old Mar 16, 2012 | 07:19 AM
Phromethius's Avatar
K&N drop in filter killed my MAF within a few months. But since then I haven't had issues. Although I haven't "reoiled" the filter since then either. I do clean it from time to time. No issues since though.
When my MAF failed a few years back one of the first things the Orgers asked me was did I put in a K&N. Seems to be a right of passage kind of thing. But yeah I agree seems like bad design too.
Old Mar 16, 2012 | 08:12 AM
cashoit's Avatar
I always jus get a dry cone.
Dont see what the advantage is for using oiled air filter
Old Mar 16, 2012 | 08:36 AM
That's exactly why I got a performance dryflow. No oil bull**** and in tests it actually provided better air flow overall and better filtration without the oil. AEM or Apexi are the top filters.
Old Mar 16, 2012 | 12:45 PM
RA030726's Avatar
I'm nutty for Nissans
I have had 3 maybe 4 different style K&N filters, never an issue.
Old Mar 16, 2012 | 12:59 PM
you running a short ram style just behind the battery? I always hear people have issues with heat?
Old Mar 16, 2012 | 06:22 PM
slowmanvns's Avatar
Maybe Fram is not nearly as good quality wise as K&N
Old Mar 17, 2012 | 12:34 AM
I know some would argue, but I never have seen Fram to be anywhere near the quality as K&N..
Old Mar 17, 2012 | 12:52 AM
schmellyfart's Avatar
Didn't have any issues when I ran a K&N Panel filter.
Old Mar 17, 2012 | 01:04 AM
max ride 41's Avatar
really??? i saw a display in pep boys where the fram could be interchanged with the k&n filter and the air flow was much better. i've ran a k&n for 6 years and the first thing they said was not to over oil the filter or it will make the car stall and f up the maf. i always let it dry for a few hours and lightly spray only 1 side before i re-install and she works great.
Old Mar 17, 2012 | 02:31 AM
I've tried very very light oil and even let it dry for 10+ hours and still would end up with problems down the road.
Old Mar 18, 2012 | 11:30 AM
GerberGuy97's Avatar
I put a K&N cone filter on my '97 with a short ram about 2 months ago. I'd heard of people have problems with oiled filters wreaking havoc on their MAF's, but I went ahead and did it anyways. Sure enough, 2 months later, the car starts bucking, losing power and stalling. I bought a re-tooled MAF for around $250 at Autozone, put the stock intake back on until I decide on a new filter, and now it runs just fine. Beware of oiled filters. I hadn't even ever cleaned the K&N, I put it on right out of the box with the factory amount of oil on it and it ruined the MAF (even after cleaning it multiple times, I couldn't resurrect it). K&N filters are great, but I'll probably stick to dry filters from now on for my Max.
Old Mar 18, 2012 | 11:33 AM
Shift_A32B's Avatar
Just switch to dry air filters. Amsoil, AEM, etc.
Old Mar 19, 2012 | 02:02 PM
kel456's Avatar
sometimes i question the claims about these performance air filters.
MAXSE5SPD
Sep 17, 2022 04:00 AM
homeyclaus
Sep 3, 2015 06:15 PM
00MAXI
Sep 2, 2015 10:23 AM
kirkhilles
Aug 8, 2015 10:53 AM
