tilt steering loose>93 SE
If the tightener lever thingy is too loose to hold the wheel, I noticed on my 240SX that you can remove the plastic housing around the steering column and on the other side of the lever is an allen head bolt held in with a spring clip to keep it from turning- the adjuster lever is just a large nut with a handle on it basically.
pull the plastic housing off the column and see if you can find that.
HTH.
HTH.
HTH.
HTH.
you are right I fixed it thanks to you
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
