wheel bearing noise. SUPER BAD!
Old Apr 3, 2012 | 06:18 PM
soundquest's Avatar
My 2003 Max is making horrible grinding noise from the front axle -- it can only be wheel bearings I am convinced at this point based on what I was able to see/inspect last night and based on what I read in numerous posts. It would seem they are a very high failure rate component on this particular gen?
My question for you all is:
do I need to replace the hub at the same time?
are there any other parts I should replace along with this at the same time?
The front struts are worn, I will likely do them at the same time.
Thanks for all your help in advance.
Old Apr 3, 2012 | 06:26 PM
TunerMaxima3000's Avatar
SUPER BAD
Don't know until it's apart, it needs to be inspected at that point and deemed good/bad by a competent inspector.
If it's super sloppy rocking back and forth when you lift the wheel, you'll probably need a hub.
are there any other parts I should replace along with this at the same time? Not unless there's other worn components. if there are, it's a good time saver to do the other stuff while it's torn apart. You can only pre-plan so much though, and taking wheels off isn't that hard.
Old Apr 3, 2012 | 07:03 PM
soundquest's Avatar
Thanks for the reply. I came up empty handed for a sticky or DIY on bearing replacement for this gen. Anyone know where I might find this? Since a shop press is needed, would you recommend I just have a shop do it? I used to have a FSM downloaded for this gen Maxima but that hard drive crashed long ago. Anyone recall where that is available for download?
Old Apr 3, 2012 | 07:08 PM
craiggers14's Avatar
Here's the FSM
http://www.nicoclub.com/FSM/maxima/2003/
Old Apr 3, 2012 | 07:30 PM
HotshotVQ35's Avatar
i have a BNIB wheel bearing i will let go for cheap, PM me if you want the info..
Old Apr 3, 2012 | 09:37 PM
soundquest's Avatar
Originally Posted by craiggers14
BINGO! craiggers I can't thank you enough!
HOKUSMAX
Nov 13, 2017 04:34 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
maximusrising
Sep 2, 2015 09:55 AM
