Car revving between 2nd and 3rd
I have a 2000 maxima, 206k miles and a new problem recently came up. My car is revving (approx. 800-1000 rpm) when shifting from 2nd to 3rd. It does it under light, moderate, and heavy loads. I have changed the transmission fluid with no luck to solving the problem. All other gear shifts are great and the car shifts like it should. Any ideas on what to check on?
The transgo kit probably won't help if the bands and clutches are worn out. At 206k I would guess it's rebuild or replace time. It could be as simple as a band adjustment though, so talking to a reputable professional may be a good idea in this case.
So I went to the nissan dealership to have them run the diagnosis. What came back was "LINE PRESSURE S/V". I believe it is reading low line pressure and threw that code. My next steps are to drop the trans pan and put a battery on each solenoid to see if it pops open. Has anyone done this and what are you experience?
Last edited by icewake; Apr 17, 2012 at 03:13 PM. Reason: edit-one more note, this did not throw the check engine code but he was able to pull it with the consult II
Replacing the solendoids is what I believe is my first option. Since the current transmission has 206k on it and I can hear a slight squeel every now and then, would any of you recommend buying a used transmission from a junkyard and having it installed? What would that cost approximately be?
Lakersallday24
Jun 16, 2019 01:35 AM
laparka66
Aug 6, 2015 09:36 AM
