Tries to start, but won't
Old Apr 25, 2012 | 06:56 PM
cheselz's Avatar
My '97 SE has a good battery. But for some reason on any random day of the week it just won't turn over. It tries and tries but I have to take the key out and start it again, after which it starts just fine. It might be the starter but is there a way to tell if it is?
Old Apr 25, 2012 | 07:02 PM
Sounds like your ignition switch.
Old Apr 25, 2012 | 08:10 PM
Trini Boom's Avatar
Old Apr 25, 2012 | 10:25 PM
DennisMik's Avatar
I don't think it's the ignition switch. The op says "It tries and tries" which I interpret to mean cranking over.
Old Apr 25, 2012 | 11:13 PM
Yeah but then he says he "removes the key and puts it back in", then it starts.
OP, if you want to test your starter, just remove it and bring it to Autozone to have it tested.
Old Apr 26, 2012 | 06:50 AM
asand1's Avatar
Bad ignition circuit contacts in the ign switch, or just slop between the lock cylinder and ign switch. We've seen it before. Search for ignition switch tape trick. On my Droid so can't post links, sorry.
Engine cranks but wont start.
Removing the key helps, which indicates the issue is there.
Old Apr 26, 2012 | 06:53 AM
asand1's Avatar
If the starter is turning the motor over(cranking), the starter is fine. Sounds like you have a "cranks, but no start" problem. Search for similar issues.
Old Apr 26, 2012 | 07:10 AM
njmaxseltd's Avatar
I agree - He states that removing the key and reinserting it starts the car.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
