jwt ecu too lean
Old May 5, 2012 | 10:25 AM
GStrength's Avatar
jwt ecu too lean
I installed my JWT ecu and after punching it a few times i get a check engine light which reads P0174 SYSTEM TOO LEAN BANK 2. Can anyone shed some light on this issue?
Old May 5, 2012 | 10:36 AM
MAXIMA_STYLE's Avatar
Ecu is no good send it to me LOL...
Old May 5, 2012 | 10:47 AM
Can you verify that it's the JWT ECU? Put your stock one back in and test to be sure. If it's the JWT, you have to send it to be reflashed.
Old May 5, 2012 | 10:53 AM
essential1's Avatar
My axles cry for mercy...
You need a wideband to verify when it goes lean. Chances are that its just lean when you let off the gas after a WOT run. You can't trust the factory O2s that much.
Old May 5, 2012 | 12:02 PM
GStrength's Avatar
My stock ecu used to throw a bad rear 02 sensor before
Old May 5, 2012 | 01:07 PM
ShocknAwe's Avatar
I agree with essential. JWT rarely messes up an ECU flash so most likely it is your 02 sensors giving a false code. If your going to start doing upgrades such as that then you need a good way to measure the vitals especially AFR. AEM has a good one but it ain't cheap. Dont get a cheap auto parts store AFR gauge as hose do essentially nothing. Lambda or bust
Old May 6, 2012 | 09:41 AM
Nealoc187's Avatar
SLOW
jwt n/a ecus are known to run a bit lean, but i would not put any stock into what a factory o2 sensor is telling you.
get a wideband if you are worried.
Old May 6, 2012 | 08:30 PM
carsnwomen91's Avatar
its not the jwt, trust.
Old May 9, 2012 | 12:23 PM
CMax03's Avatar
Bad O2 sensor!
Old May 9, 2012 | 12:35 PM
NmexMAX's Avatar
dot dot dot ...
14.0 and slightly above
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
