HI Keyless entry / FOB remote
I have a couple of remotes for sale. A269ZUA078
I also have a keyless ecu computer controller (if you don't have a working one in your car)
They are working and are intact (can be attached to a keychain)
FOB- $20 shipped each (2 for $38)
keyless ecu- $20 shipped
PM me or email me at kaneda_77@hotmail.com
All 4th gens came with the wireless keyfob. Factory. Standard. They work even if you have an aftermarket alarm, though you might need to disconnect it or sync it with the aftermarket. If you just want the keyfob, you can find directions for how to online, ie: http://programyourremote.com/
Every maxima that I have ever seen has had keyfob capability. I have read where it suggests that some may not have the system(ecu) installed. You can find the keyless computer in your trunk on the right side by the power antenna.
Programming is easy...
1.Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds
3.Hazard lights should flash
4.Put key back into the ignition & turn to Accessory
5.Press the master door lock (on drivers door arm rest) unlock/lock
6.Hit the lock button on the remote
7.Hazards should flash
8.Pull key out and open the drivers door and then close it
9.It should be set
These instructions worked perfectly for me. If you have more than one remote, I believe that you repeat step 6 for each remote before performing step 8.
9.It should be set
