starts but won't stay running - 2002
Old Jun 3, 2012 | 05:03 AM
paradiddle's Avatar
02 - 5th gen Maxima - starts but won't stay running. it will only idle barely for about 10 secs and die and will not respond to throttle. No codes.
Because I could not test the fuel pressure and went on a hunch and got a pump and strainer. They did not have the filter assy. I put that in and it did not change. I am going to get a Nissan filter from CP as they are cheap. It had a lot of small debris coming out of it when I was assembling but I do not think that alone would cause the problem I have.
I was able to jury rig a pressure guage on the pump outlet and got 43 psi but I would rather have connected that with a t connection in running condition. I don't know why Nissan didn't have a connector.
Am I chasing the wrong thing here? I also clean the MAF sensor. I still think its fuel related.
Old Jun 3, 2012 | 05:20 AM
paradiddle's Avatar
will this adapter work on pressure rail ?
Old Jun 3, 2012 | 05:50 AM
paradiddle's Avatar
I just unplugged MAF and now it will idle and run up to 2200rpm.
I found info on this thread
http://forums.maxima.org/5th-generat...y-running.html
Old Jun 4, 2012 | 04:56 PM
DjHackStyle's Avatar
ok since now you know its a MAF problem you will notice that MAF sensors for a 2002 are maddd expensive. well don't worry there is a solution. do not ever buy a aftermarket MAF sensor because you will waste your money, happened to me 2 times. you gotta get a original nissan maf sensor but a 2002 sensor is like $442. so you gotta get the maf sensor for a 2000-2001 maxima, its like $90. i think this is the sensor i found it on courtesyparts.com
http://www.courtesyparts.com/22680-m...957_1973_1976&
im pretty sure thats the sensor, and once you get this sensor you uninstall yours and you transfer over a little thermistor thing from the old sensor onto your new sensor and your good to go. look on the org there is a whole post about this and how to do it. save yourself the money and get the right part you will be happy.
Old Jun 8, 2012 | 04:27 AM
paradiddle's Avatar
I had already ordered the aftermarket MAF sensor from Ebay and just got it and plugged in and it seems to run ok. What will happen now ? The aftermarket had no thermistor
Old Jun 8, 2012 | 04:33 AM
cjandura's Avatar
Swap over the therm from your old maf and solder it in place they hardly ever go bad
Old Jun 8, 2012 | 07:19 AM
paradiddle's Avatar
what does the thermistor do ? and I take it it's not ok to run without it.
Old Jun 8, 2012 | 04:45 PM
paradiddle's Avatar
The ebay seller responded that it did not need a thermistor. But I already soldered the old one on the new one. I may take it back off per seller instructions and see what happens. Its running good again.......
Old Jan 19, 2013 | 01:58 PM
paradiddle's Avatar
I think I have had 2 bad ebay MAF sensors and now it's time to getthe one you suggested. !!
Old May 16, 2015 | 06:25 PM
mikayla1969's Avatar
Does it matter if my maxima is a 3.5l not a 3.0 for this to work, using a 2001 MAF on my 2002?
Old Sep 6, 2016 | 10:31 AM
96SEmaxB's Avatar
My 19$ EBAY MAF lasted about 4 months and just **** on me this am at 5:20am, so spending the 90$ and soldering thermo is worth it.
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
fastcarny
Aug 12, 2015 03:50 PM
yat70458
Aug 3, 2015 01:16 PM
