FALKEN Ziex 502
Originally posted by SkyMax
I had a set of Falken Ziex tires and I liked them. Only problem was that they wear down pretty quick. I recommend them over my set of Toyo Proxes FZ4 tires.
Originally posted by DAREN
hey skymax what dont you like about the fz4's. i've had mine for about 15k of some-what abusive miles and they have done pretty good. are there any particlar problems i should be looking for.
What I don't like about my FZ4's is that when your tire is low with air, then there is a crease that is created in the sidewall therefore your tire is ruined and must be replaced. I never had that problem with my Falkens. When air is low, I just put some more in and it's fine. There's no crease in the sidewall. Also, I think my Falkens handle better in twisty roads compared to my FZ4's when they were both new.
if you havent already try 40-42psi and see how you like them
hope his helps.
NOISE, passengers have thought I had a flat. Traction is good in the corners but they spin just as easy as the Mastercrafts that came with the car. On the bright side they have a kick *** tread pattern. I have ABS so I cant give any input as far as braking goes
If they've got noise like a bad tire or anything like that, then you've either got a bad suspension component, a bad belt in the tire, bad balance, something that's causing a vibration of some sort.
FYI. Mastercraft tires are a "cheapie" generic brand tire. there's a few places around here that sell them, and they usually only sell other cheap brands like cooper or Dayton.
I actualy read Darens upped the psi and it helped A little
and the Suspension could use a little work the car is starting to pull to the right little. Oh and I meant came with the car when I bought in September
maxracer27
Nov 24, 2002 08:25 PM
PATRICK94SE
Jun 26, 2002 04:20 PM
ispeed
19
Dec 14, 2001 04:11 PM
cuz I sell toyos too and i dont really care for them. just my $0.02
