Consult II Timing Advance Question!!!
Old Jun 25, 2012 | 07:56 AM
2000_Maxima_SE's Avatar
I went to the Nissan Dealership today to get my timing advance done. However, I was not able to and paid them $33.44!!! Here are their reasons.
1. Consult II can only advance timing when the engine is at 150 degrees.
2. Consult II cannot advance timing when there is a check engine light (I got code P0325, P0139, P0138).
Are these TRUE statements about the Consult II?
Old Jun 25, 2012 | 08:55 AM
Grand_hustle17's Avatar
Not true... did mines after the car was sitting for maybe an hour... cant remember if i had a CEL
Old Jun 25, 2012 | 10:04 AM
Chris Gregg's Avatar
Get Off My Lawn
Posted in your other thread. But I'm confused because only your O2 codes are consistently mentioned.
I don't know what the 0435 is, but the 0425 you mentioned in your other thread is the knock sensor. The secondary O2's should had been able to be cleared as they do not affect fuel trim. However, if your other code is indeed a knock sensor, the mechanic did you a favor. Regardless of whether Consult can make a timing change with those codes, a good mechanic would never adjust timing with a bad knock sensor code. To do so IMO would be negligent.
On another note, I know the 5.5 gens had a knock sensor or cps sensor recall (I'd have to look). Be a good idea to research recalls for you year and have the dealer verify if they had been done.
Old Jun 25, 2012 | 11:18 AM
MrEous's Avatar
^ Jeff™
I don't know about Consult II operation but my Cipher can change my timing right now with the codes I have.
*shrug
Old Jun 25, 2012 | 12:10 PM
Get Off My Lawn
MrEous: you should presently be seeing Error P0402 - terminal post redundancy found.
J/k.....
Old Jun 25, 2012 | 05:36 PM
MrEous's Avatar
^ Jeff™
^^ Lol not sure what happened. Earlier when I tried replying the connection timed out. Guess it worked multiple times.
Old Jun 25, 2012 | 06:28 PM
The dealership did clear the codes. I will be replacing the knock sensor. Hopefully they can advance the timing afterwards. Does anyone have a recommendation for a device that can check/clear/advance timing? I don't think Cipher or Bullydog work on the 5th gen maxima, only the 5.5 gen maxima. Seems like the Greddy Emanage Ultimate is the only option for the 5th gen maxima?
Old Jun 26, 2012 | 10:27 AM
Prophecy99's Avatar
http://forums.maxima.org/5th-generat...uestion-2.html
just in case, a good read on this mod
Old Jun 26, 2012 | 10:20 PM
Thanks Prophecy99! It was a good read.
Old Jun 28, 2012 | 09:45 AM
nishfish871's Avatar
You got a cipher and your holding out!!
Old Jun 28, 2012 | 09:53 AM
NmexMAX's Avatar
dot dot dot ...
1.) Cipher, which uses the Consult interface, will not advance timing or adjust idle if the ECT is not above 150ºF. They're right on that.
2.) I have 4 codes, and have had up to 6, and it can advance it, of course it might be depending on the codes. 138 and 139 are O2 sensor codes, not sure what 325 is.
They tried that BS with me when I went in long ago, "can't do it because codes". I left like a bat out of hell. Went back a little calmer, and they did it, regardless of the codes, but mine were 4 primary O2 sensor codes.
Old Jun 28, 2012 | 10:44 AM
user name001's Avatar
wierd.. cuz i had mine advanced with cypher, and it sat all day, then moved 5 feet into a shop.. i hooked up my generic ODB with live data after to check and it was at 17..
Old Jun 28, 2012 | 12:03 PM
NmexMAX's Avatar
dot dot dot ...
I think you misunderstood what we were saying. Sure it will be 17 no mater the time of day night, evening, apocalypse, etc.
We are saying Cipher wont let you advance it until it's at operating temp, after that, it will always be at that, no matter the ECT.
Same with idle.
Old Jun 28, 2012 | 03:11 PM
i didnt write that correctly lol,
my car sat outside my shop all day, then rolled 5 feet into a shop next door, they advanced it with cypher, timing was bumped to 17 degree's from 15 degree's when it wasnt at operating temp. i did check it after he was done with my generic scan tool and it was at 17 degrees, so somehow he did do it when it wasnt at op. temp.
hmm.. cuz that does make sence that it would have to be at operating temps to change it.. and why the FSM asks u to warm the car up to op. temps befor doing any self diagnosis.
Old Jun 28, 2012 | 03:32 PM
NmexMAX's Avatar
dot dot dot ...
My Cipher wont let me do it.
I go to "Adjust Base Timing", and click on it, and if it's not at temp, a window showing the ECT if it's below 60 some C or 150F.
Old Jun 28, 2012 | 09:39 PM
So Cipher does work for the 5th gen Maxima then? I haven't installed the new knock sensor yet. Still trying to find a write up on how to remove the Intake Manifold to get to it. Then I'll go back to the dealership again to see if they can advance the timing. Man, wished there was someone with CIPHER here in the Midwest that could do it for me.
Old Jun 29, 2012 | 02:41 PM
shaks's Avatar
same was for me when I was trying to change timing with SnapOn computer - won't work before car is warmed up
Old May 28, 2013 | 05:54 PM
TravisCadello's Avatar
I'm at 15. whats most i can Advance it without problems? 17 basicly safest? is their a loss in gas milege?
00 max.
Old May 29, 2013 | 06:51 AM
MrEous's Avatar
^ Jeff™
17 is basically the safest...there shouldn't be a loss in gas mileage unless you find yourself with a heavier foot than before. But really, the timing advance is probably good for 1-2hp at most?
Old May 29, 2013 | 07:59 AM
ya. but i have no power below 2krpm and throttle response is sloppy.
Old May 29, 2013 | 11:43 AM
NmexMAX's Avatar
dot dot dot ...
You cannot advance higher than 17º, Consult wont allow it. Seems as if you have more problems than just your timing is off.
I change mine from 13-17 and there's not much difference. Maybe a slight difference in throttle response, and the idle changes slightly.
Old May 29, 2013 | 03:43 PM
Ya every last oxygen sensor is bad lol probably should change those first cause its as weak as a civic till 4k rpms.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Balkins
Feb 1, 2016 12:45 AM
incubusjohnny
Nov 3, 2015 05:18 PM
Starrider
Sep 17, 2015 07:26 AM
1992maximase30
Aug 5, 2015 09:27 PM
