control arm bolt is STUCK
i'm actully pretty pissed and SHOCKED at this.
yesterday i go to do my driver side arm. I did the pass side about a month ago. No problems at all.
Pop off the ball joint nut and broke it free. Did the 3 rear ones with the tray. My IR impact made short work of that. I get to the one with the silver pin. I did the middle first and then the rear half way. So now only one left is front.
WTF it does budge at all. I'm shocked because the other 5 bolts came off without much effort via impact. So i opted to fully charge up my 20 gal compressor AND then have at it something. Will not move, PB blaster and waited and still nothing! I even took out the breaker bar. This single bolt made me put everything back together and i'm extremely pissed right now but have NO idea what to do.
Pass side didn't give me any issues. So why is this one fighting me. I think if i keep at it, i might round off the bolt or my socket.
My impact isn't weak as i can take off crank pulleys in about 5 seconds, i had my impact on that control arm bolt for 30 seconds before my arm got tired.
Keep soaking it with PB Blaster for a week or so and hit it again with you impact gun. You might try and hit it with the impact gun to tighten it first and then loosen it to break all the rust and corrosion free. Heat is your next option. Last resort is a length of pipe on your breaker bar but one thing is for sure there it will either break or come loose.
Ive never seen a bolt that heat and blaster cant move. Either that or it breaks. Order yourself a new bolt and go into the job telling yourself "its coming off either way" lol and it will go. When I say heat I mean a torch and heating it up until its red not just warming it up
I just did both my LCA's this weekend and ran into the same problem. I also have the IR impact and it would not budge even at full power.
Take a hammer (didn't even need the 5lb sledge) and just hit the head of the bolt a few times. After a few good hits on it, the gun took it right out.
The tops of those bolts in my car were covered in what appeared to be the factories version of loctite. Once I got that broken free with the hammer, the bolt came right out.
