Mass Air Flow Sensor replaced
Ran codes and determined Mass Air Flow was out. Replaced it myself. ECL is still on and car still hestiates at acceleration, hill climbing, etc. Will ECl cycle off and will ECM reset itself or what to do? Help guys.
it should have been solved when you connected it are you sure it was installed properly or are the connector wires loose. and its CEL
What were the codes that lead you to the MAF?
Check the electrical connection, more specifically the connections within the connector itself. Look for lose, frayed or corrosion on both sides of the connector.
Did you try and clean the OEM MAF? Take some MAF cleaner and spray the heck out of that little wire inside. I took an acid brush and cleaned the heck out of it. That little wire in there is more robust than I thought it would be, in fact its real solid.
That worked wonders for me.
Another thing to check with MAF. When you remove the MAF ftom the manifold, there is a round rubber piece between the MAF and the intake. Nissan calls it an "isolator." If it is hardened or cracked, it will also need to be replaced. Costs about $10 at the dealer. If the isolator is bad, it will leak unmetered air into the intake behind the MAF, thus confusing the ECU. I didn't realize it was bad on my car until I was actually changing the MAF; had to run up to the dealer and get a new one.
old thread, new post. got a p 0100 which is the code for maf. thanks to cs ar i got a replacement one. seems simple enough, but what do i have to remove before putting the new one on? write-up somewhere in here, video? sorry, i'm tired and the max is idling like crap.
Just leave car off, open hood, disconnect wire harness from MAF and loosen both clamps on either end to slip out. Make sure the rubber insulators are good and install new MAF and reverse the steps I just mentioned. My MAF seems to start going out as it randomly stalls coming to a stop sometimes but no code yet.
http://www.ebay.com/itm/NEW-GENUINE-...FXH4Yo&vxp=mtr
edit: called the dealer this morning and got it for $11.00!! woot!
bc992164
Aug 26, 2015 12:19 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
