Whew what a week for car work!-->
Old Nov 10, 2000 | 05:12 PM
Jeff92se's Avatar
I'm needing a caw
New Nissan clutch in, lightened stock flywheel in and new flanges for the RT cat in. Stock flywheel is only 19lbs. Tey shaved/balanced the flywheel/pressure plate together. I put the flywheel back on the scale and they took off 3 lbs. Not a whole lot but it adds up I guess. Once I got the proper RT cat flanges installed(BTW ball socket type flanges are far superior than the crap stock RT flanges or even flat flanges. No gaskets needed w/ this set-up. I recommend this if anyone is getting custom stuff done. Car has it's lowend back(from leaky exhaust flanges) and seems to rev faster w/ the lighter flywheel. Tranny work is almost easy now. The cost of lightening/resufacing/balancing the flywheel and pressure plate was about $160.
Old Nov 10, 2000 | 05:18 PM
brianw's Avatar
Sweet!!
What exactly is a ball/socket type flange....?
Old Nov 10, 2000 | 08:54 PM
Jeff92se's Avatar
I'm needing a caw
Sorta hard to explain. I didn't take photos becuase I ran outa film. Plus judging by the pathetic response to this post, no one wouldn't know a good thing if it hit them in the face anyway. If I take a pic, I'll email what it looks like Brian.
Old Nov 10, 2000 | 10:05 PM
Nismo87SE's Avatar
Actually not many realize how complex it is to do this type of work. Believe me I have a good idea. How about you fly down to houston and help me pull my engine/tranny . Hell we could do my SE-R clutch at the sametime .
Old Nov 11, 2000 | 10:18 AM
Jeff92se's Avatar
I'm needing a caw
Sure Nismo! I'll undo the top bolts and you handle the underside. Heh, that's how me and my bro work. We've done it so many times now, we barely even have to talk to each other. BTW your right about the seal puller. There is a special tool(parts guy at Nissan showed me) Could have saved me alot of headache. Do me a favor, if you take the flywheel off, weigh it for me.
Old Nov 12, 2000 | 12:18 AM
Lordrandall's Avatar
Hey Jeff, I'd like pics of your new flanges too....
Old Nov 14, 2000 | 02:27 PM
Jeff92se's Avatar
I'm needing a caw
Her's an assembled pic for the ball socket. This pic is a Pacesetter header though. (duh) but you get the idea. No gaskets. The upper portion is like a ball and the under portion is like a socket that fits over the ball. The the two flanges keep them together.
<img src=http://www.impactparts.com/neon/media/nnhdr.jpg>
Originally posted by brianw
Sweet!!
Old Nov 14, 2000 | 02:33 PM
DanNY's Avatar
Ad·min·is·tra·tor
does it look anything like a curved T..sorta like a hammer?
Dan
Old Nov 14, 2000 | 02:35 PM
Jeff92se's Avatar
I'm needing a caw
Yes that's exactly what it looks like.
Dan
Old Nov 14, 2000 | 02:49 PM
DanNY's Avatar
Ad·min·is·tra·tor
i think i have one of those laying around. if not something i need to get.
Dan
Dan
Old Nov 14, 2000 | 02:56 PM
Shingles's Avatar
The missing moderator
hey jeff...
3 lbs is a lot on the flywheel... there is a formula out there that I don't recall, but a few lbs = a few hundred pounds on the car... btw (you probably know this) but the effect is different in each gear... meaning the effectiveness gets less with each gear shift...
-Shing
Old Oct 31, 2001 | 03:36 PM
Jeff92se's Avatar
I'm needing a caw
Thanks for the info Shing!
Old Oct 31, 2001 | 03:39 PM
emax02's Avatar
Bored?
Old Nov 1, 2001 | 12:14 AM
Nismo87SE's Avatar
Jeff the archiver
Man you really dug this thread from the grave .
Lakersallday24
Jun 16, 2019 01:35 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Balkins
Aug 12, 2015 06:39 AM
kenc15
Aug 5, 2015 08:29 AM
yat70458
Aug 3, 2015 01:16 PM
