Low beam hids!
Low beam hids!
Just got some for my fogs and low beams. However, I've read and try searching the forum about how to install the low beams..but all I saw was the fogs. How do I get to the low beam bulbs? Remove the headlight assembly? Bumper? Thanks in advance.
easiest way is to cut your wheel to the side and go in through the wheel well fender liner. since you have high beams it'll be more of a pain cause you have to twist the grey cover off the back of the headlight, then pinch two clips to get the HID bulb out and then disconnect it from the harness. it may make it easier to jack up your car, take off your wheel and take more of the liner off so you have more room to work
litch
123
Jan 4, 2024 07:01 PM
