Bolt hole?
Old Sep 6, 2012 | 04:03 PM
s.hebard82's Avatar
Bolt hole?
Hello again fellas. I got to finally cranking this bad boy over and noticed a slight oil leak. I took off the alternator and oil filter bracket and came to a problem in which I'm now asking the question.....about 3 inches from the oil filter bracket to the right of the bracket there is a huge maybe 13/14 mm threaded hole. I was trying to figure out what tied into it. I know it's not electrical as all of my wires are plugged in minus the oil wire that plugs into the oil filter braket. This is where I'm guessing. Maybe some kind of mechanical oil sensor of some sort. Not really sure. I'm sorry if this isn't very informative but all I know is it's a considerably sized bolt/sensor that threads into it. Any ideas? I'll try and post a pic on here shortly as I'm sure that might help someone. I know with the alternator and oil filter bracket, it's practically invisible. I was even maybe guessing that it's some kind of oil return line for a turbo set up. Thought maybe some of these are turbos in Japan or something. Thanks for everyone's time viewing this.
Old Sep 6, 2012 | 06:16 PM
James92SE's Avatar
2 VE's are better than one!
I just checked on my spare engine in the garage and mine just has a bolt there threaded into it.
And you're right - it isn't noticeable at all (in fact I've never noticed it before specifically looking for it now).
Old Sep 6, 2012 | 06:22 PM
DanNY's Avatar
Ad·min·is·tra·tor
looks like it's the bolt hole to feed the turbo.
Old Sep 6, 2012 | 07:53 PM
chrome91's Avatar
could that be a hole to thread in a oil pressure gauge?
Old Sep 7, 2012 | 06:50 AM
s.hebard82's Avatar
Thanks!
Hello. Wow.....thanks for the help everyone. That's what I kinda thought on it. Thank god you had a spare motor to check out for me. I really appreciate it fellas. Now.....off to figure out the anti theft issue I'm having
Old Sep 7, 2012 | 06:54 AM
DanNY's Avatar
Ad·min·is·tra·tor
i guess you can use it for that. ppl generally tee off the stock fitting.
Old Sep 7, 2012 | 07:05 AM
Matt93SE's Avatar
STFU n00b!
Do you have a strut tower brace? Often they hold the hood up just enough to cause the hood switch to freak out if you get a stiff breeze across the car and the hood moves a touch in the wind. been there, done that.
If it doesn't disarm properly when you open the doors, that's usually due to the contacts inside the door lock getting dirty. The factory alarm has disarm contacts at each front door lock to disarm when you turn the key in the door.
(FYI, that's the only way to shut off the stock alarm. put key in door and turn. voila.)
Can't help much on the hole in the block, but it looks like related obviously. stick a bolt in it with appropriate crush washer and call it a day.
Old Sep 7, 2012 | 08:19 AM
shiloh51933's Avatar
Looks like it has been making a mess but better that than a seal. Get the right bolt /washer for it from Nissan then clean her up to make sure nothing else is leaking.
Old Sep 9, 2012 | 08:41 PM
CMax03's Avatar
Is this a VE? It could be a plug that fits there.....?
Old Sep 10, 2012 | 06:52 PM
maximo018's Avatar
Yeah its a VE. Just some random bolt.
litch
123
Jan 4, 2024 07:01 PM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
