Help!!!!! Fuel Leak?!?!?!
I have a 1998 automatic Maxima se that has been great up until now. It has 278,000 miles on the original drive train. The problem is now there is fuel poring out the back of the block when it’s running. It is hard to see back there because of the fire wall. The gas is building up behind the drive shaft/passenger wheel and at a high rate. There is also a white mist coming from the exhaust pipe. Could it be?
a) A leaking or stuck injector causing fuel to puddle in the intake a leak out.
b) A blown head gasket.
Or c) A injector seal or fuel line leak.
I’m going to take the upper intake man. off but If I do that I cant start the engine which also means I can not see where the leak is coming from.
Has anyone come across this or heard of it before.
Please chime in with some good information.
Thanks in advance.
I did do a search and Im having the same issue as this guy http://forums.maxima.org/4th-generation-maxima-1995-1999/588247-very-unusual-fuel-leak-help.html but of couse he did not post a resolution to the problem.
Thanks! Ill have to wait to this weekend when I can remove the intake manifold.
I did do a search and Im having the same issue as this guy http://forums.maxima.org/4th-generat...leak-help.html but of couse he did not post a resolution to the problem.
no! Its been sitting for about a month now. I have not had time to look at it. I have two other cars to drive. But my lil sister needs a car. I was going to fix it and give it to her.
Another fuel system question
When I fill up my 95 Max sometimes I get a fuel smell in and around the car for a bit. I've been over the car bumper to bumper and can't find any leaks. Gas mileage is unchanged, is something wrong or am I just nuts?
Very informative read
Thanks in advance.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
