5.5 Clutch Replacement
Old Nov 9, 2012 | 01:58 PM
rebelhell's Avatar
I've just noticed that my clutch is beginning to slip. I am going to attempt to replace it myself. I know I need a clutch disk, clutch cover, release bearing, alignment tool, and pilot bushing. Is there anything else I need, or anything else I should replace while the transmission is out? I have a stock 2002 with 151,000 miles.
Old Nov 9, 2012 | 05:59 PM
nsnrider's Avatar
new gear oil
might aswell put new axle seals
Old Nov 28, 2012 | 08:20 AM
rebelhell's Avatar
Another question, should I go with an OEM clutch or a performance aftermarket? Any other brand you'd recommend?
Old Nov 28, 2012 | 08:33 AM
02whitemaximase's Avatar
Check rear main seal too, have to pull the tranny to replace that.
Old Nov 28, 2012 | 08:36 AM
rebelhell's Avatar
Yeah, that's on the list. Might just buy one and replace it for the heck of it. I know it's not leaking now but...151,000 miles...
Old Nov 28, 2012 | 08:31 PM
rebelhell's Avatar
Any recommendations on clutch brand? Should I go with a performance clutch or just OEM?
Old Nov 28, 2012 | 09:01 PM
artilarygoboom's Avatar
if you plan on keeping it for a while and drive it daily, go with an oem but a "stage 1" clutch would just give you more a bite but you prolly wouldnt notice it. anything stronger then that is not needed unless your going forced induction. I had a stage 3 6 puck clutch on my old integra that i boosted and it was not fun to drive daily. Or you can do what other people have done and put the 350Z clutch in.
Old Nov 28, 2012 | 09:08 PM
rebelhell's Avatar
It is definitely a DD. I put about 90-100 miles a day on her. I would love to do forced induction but I doubt it will ever happen, just a bit too pricey and I wouldn't know where to start. Is the 350Z clutch a direct replacement? How is it better than the Max OEM clutch?
Old Nov 29, 2012 | 04:16 AM
Be careful with that z clutch, it is sprung which means having a dual mass flywheel like we do, could be an issue.
Old Nov 29, 2012 | 08:41 AM
LazYRaCeR's Avatar
Oem
Old Nov 29, 2012 | 09:29 AM
rebelhell's Avatar
Gotcha
OEM sounds good.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Finkle
Sep 27, 2015 09:53 PM
vanebecker
Aug 17, 2015 08:24 PM
