unloaded calipers
Old Nov 12, 2012 | 10:53 AM
jake0330's Avatar
unloaded calipers
I ordered a set of unloaded calipers for my 98 Nissan maxima is there anything that I will need to buy before I install them? can I use the old mounting bolts?
Posted from Maxima.org App for Android
Old Nov 12, 2012 | 10:57 AM
[s3]'s Avatar
Besides brake pads, swap calipers out and used old mounting hardware.
Old Nov 12, 2012 | 11:09 AM
jake0330's Avatar
thanks, is there anything I should look for? this is my first time, I know I need to bleed them after, someone mentioned to me that they might require a special tool?
Old Nov 12, 2012 | 11:19 AM
[s3]'s Avatar
Are your calipers seized? and which ones are you replacing?
Fronts and back?
Old Nov 12, 2012 | 11:36 AM
jake0330's Avatar
yea they are frozen, the rears
Old Nov 12, 2012 | 11:44 AM
[s3]'s Avatar
You'll need to bleed the brakes after the install. You'll need these supplies.
1) Brake fluid, 1 bottle should do it
2) Clear vinyl hose (Autozone should have) Should fit over the bleeder nipple
3) Someone to help you bleed the brakes or buy a vacuum bleeder kit
something like this
Amazon Amazon
Old Nov 12, 2012 | 11:50 AM
jake0330's Avatar
sweet thanks for the help!
Old Nov 12, 2012 | 11:51 AM
vgq2's Avatar
You probably already know this but the rear caliber pistons turn so have the tool to turn it. Otherwise, everything is good. Oh, and don't forget to put those retainer shim things on.
Old Nov 12, 2012 | 11:59 AM
[s3]'s Avatar
Probably will have a very tough time turning them...seized
Old Nov 12, 2012 | 04:42 PM
jake0330's Avatar
do u know the name of the tool? this is my first attempt at doing this haha, any info will help
Old Nov 12, 2012 | 05:03 PM
vgq2's Avatar
I meant the replacements, when he puts them on they probably wont yet be compressed. And I have no clue what its actually called I think i bought it as a piston compressor/rotator or something along those lines. They have it at all the local auto parts places and it basically is a cube with a 3/4 socket hole that you stick an extension in. There is a different pattern on each side for different cars so pick the one that applies and then the extension -> ratchet goes on the opposite side. I just did my brakes and had a hell of a time compressing those rears.
Old Nov 12, 2012 | 05:25 PM
jake0330's Avatar
jeez maybe I should look for someone who has done this before to help me, is there any good step by step videos u guys know of?
Old Nov 12, 2012 | 06:52 PM
[s3]'s Avatar
Amazon Amazon
Old Nov 12, 2012 | 07:03 PM
Uriel's Avatar
I just replaced my rear calipers and I used the bolt that came with the calipers. Don't forget to buy brake grease. Wal-Mart sells them. Also don't forget to torque your bolts.
Old Nov 12, 2012 | 07:07 PM
Uriel's Avatar
Just get you a clear hose line that will fit over the nipple of the bleeder screw so that you can see the air coming out of the system. Once all the air is out (no more bubbles) you are good to go.
Old Nov 13, 2012 | 05:36 AM
jake0330's Avatar
I also need to replace the rotors, what do u guys think I should go with?
Old Nov 13, 2012 | 06:08 AM
vgq2's Avatar
I just changed mine also. To be quite honest I was fine getting some ebay ones. They came in a set of 4x zinc coated slotted/drilled with 4x ceramic pads for like 190 or so. I haven't tried jamming the brakes yet but after bedding them they work fine for my every day driving.
Old Nov 13, 2012 | 06:49 AM
[s3]'s Avatar
Ebay specials
Old Nov 13, 2012 | 07:21 AM
jake0330's Avatar
eBay is where I got the calipers, they were $75 refurbished but unloaded
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
