2000 maxima se no power locks
as stated in the title. the power locks and remote entry unlock/lock doesnt work anymore. seemed like it went bad over night. everything is fine just have to use key to open the car. what can be the cause behind this?
If you open the covers there should be a diagram that will show what each fuse is for. Also check the FSM. Here's a link if you don't have one. http://www.nicoclub.com/FSM/
If you are looking to reprogram your remote, these are the steps
1.Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds
3.Hazard lights should flash
4.Put key back into the ignition & turn to Accessory
5.Press the master door lock (on drivers door arm rest) unlock/lock
6.Hit the lock button on the remote
7.Hazards should flash
8.Pull key out and open the drivers door and then close it
9.It should be set
9.It should be set
9.It should be set
9.It should be set
King_Ten_Ahead
Sep 30, 2015 04:27 PM
jholley
Aug 11, 2015 09:38 AM
kjm900r
Aug 5, 2015 07:14 AM
