Oil pan gasket question
Old Nov 28, 2012 | 12:27 PM
anthony18's Avatar
I just put on a oil pan gasket on my 98 max due to oil leak there was no gasket on at all which was odd but anyways. How long do I have to wait to my oil back in a test drive?
Old Nov 28, 2012 | 01:45 PM
Shift_A32B's Avatar
That's because the oil pan is sealed by RTV silicone not a gasket
Old Nov 28, 2012 | 02:10 PM
[s3]'s Avatar
Hope he scraped off the old gasket before he put the new "gasket" on
Old Nov 28, 2012 | 03:43 PM
anthony18's Avatar
Yeah I did I'm not a dumb *** just was trying to figure out how long I have to wait before I test drive my car after I reinstalled my oil pan. Out all the ppl in this forum I still get dumb *** responses
Old Nov 28, 2012 | 03:45 PM
anthony18's Avatar
Old Nov 28, 2012 | 07:18 PM
iDuty's Avatar
I would let the RTV set overnight before filling with oil and starting the engine.
Old Nov 28, 2012 | 08:21 PM
Quickywd01's Avatar
You made it sound funny but anyway your answer is on the product you used. Some products have different drying times.
Old Nov 29, 2012 | 07:32 PM
Nealoc187's Avatar
SLOW
the first time I ever did an engine swap I put RTV on the lower oil pan and had oil in the thing within 3 hours. it never leaked.
Old Nov 29, 2012 | 07:41 PM
asand1's Avatar
VWs' use white RTV. At the dealership we didn't wait at all.
Old Nov 30, 2012 | 06:09 PM
Snypa's Avatar
grey all day. Mechanics don't wait either.they do and send you on your jolly way. Last time I did it, I gave it like 3 hours before filling with oil and starting engine.
Old Dec 1, 2012 | 04:55 AM
Trini Boom's Avatar
I actually let mine sit 24 hours before filling back with oil on a summer day. Seeing that its a bit colder, same time might be ok.
Old Dec 1, 2012 | 05:00 AM
anthony18's Avatar
Thanks for all the replies Unfortunately after I reinstalled my oil pan my sister took my car -.- so now I might have to redo it do to a bigger leak
Old Dec 1, 2012 | 07:23 AM
Markusfisher's Avatar
RTV has awesome instructions on the tube and packaging. Something like apply it wait 15 minutes until it's tacky reinstall and start engine next day.
Old Dec 2, 2012 | 09:17 PM
anthony18's Avatar
Well now since I have to re seal my oil pan which is better? ultra grey only or ultra grey with an oil pan gasket
Old Dec 2, 2012 | 09:36 PM
asand1's Avatar
Why do you have to reseal it again? What does your sister driving it have to do with anything? Nissan didn't use a gasket, why should you?
Old Dec 2, 2012 | 10:25 PM
anthony18's Avatar
Because she drove it 30 minutes after I reinstalled the oil pan and I was wondering which one would create a better seal
Old Dec 2, 2012 | 10:43 PM
asand1's Avatar
I fail to see the problem. Is it still leaking? When I worked in the VW dealership we sent them out as quick as we could put the oil back in.
Old Dec 2, 2012 | 10:46 PM
asand1's Avatar
Edited for ignorance.
Old Dec 2, 2012 | 11:17 PM
anthony18's Avatar
There's still a leak and maybe VW are different and I'm referring to the lower oil pan but what do you mean by cork I have picture in the beginning of the thread i think it's just aluminum on steel
Old Dec 2, 2012 | 11:33 PM
asand1's Avatar
Old Dec 3, 2012 | 10:23 AM
Quickywd01's Avatar
Did you clean the mating surfaces with alcohol or something to get it oil free? If you applied rtv on an oily surface it won't stick.
Old Dec 5, 2012 | 05:43 AM
Trini Boom's Avatar
Originally Posted by asand1
If you are referring to the the lower stamped steel pan, then yes it needs a gasket. If it is cork DO NOT use RTV, as it will chemically react and eat the cork. The upper pan does not use a gasket, just RTV.
I advise against using cork as a gasket, there was a thread somewhere on a here as a result of it and when it rots, you will not like the results of it inside your engine. Yes the filter screen is there but still I wouldn't think about using that. Just RTV only.
Old Dec 5, 2012 | 04:23 PM
anthony18's Avatar
Yeah I won't use cork I should just use ultra grey with no gasket because I'm getting a new car in a couple of months
Old Dec 5, 2012 | 05:40 PM
Nealoc187's Avatar
SLOW
since when does our lower oil pan use a gasket? am i going crazy? granted I haven't had the oil pan off a VQ in a few years but I don't remember there ever being a gasket in all the VQs I've ever torn down, assembled, worked on, etc.
Old Dec 5, 2012 | 05:49 PM
surban1's Avatar
the lower stamped steel oil pan has a gasket available at rockauto & etc. the mating surface between the block and the "oil pan" (as known to nissan) known as the "upper oil pan" around here, uses rtv.
Old Dec 7, 2012 | 08:10 PM
Trini Boom's Avatar
OEM does not have a gasket for it. Aftermarket suppliers are making one for what reason, I don't know.
Old Dec 7, 2012 | 09:33 PM
anthony18's Avatar
I'm only referring to the lower oil pan not the upper oil pan that's a different ball game there. I'm leaking everywhere but don't have the time nor funds to fix them so my car will be driven till It can't move anymore then ill part her out
Old Dec 8, 2012 | 01:23 PM
Nealoc187's Avatar
SLOW
that's what we're saying. the lower oil pan does not have any gasket from the factory. it uses rtv only (just as the upper oil pan does, though the lower uses a greater quantity because you are mating stamped steel to machined aluminum).
Old Dec 9, 2012 | 02:42 PM
asand1's Avatar
Apologies, I have never had the pan off my engine.
I was looking through the FSM earlier today and realized my error. FSM does in fact call for RTV on the lower pan.
I was speaking from experience in general auto repair. Usually stamped steel pans would have a gasket, the VQ does not.
kjlouis
Oct 3, 2015 05:29 AM
The Wizard
24
Oct 1, 2015 08:47 PM
ag90fox
Sep 9, 2015 12:22 PM
videomano
Sep 8, 2015 03:28 PM
sdotcarter
Sep 2, 2015 09:53 PM
