compression test engine outside of car
Old Nov 28, 2012 | 02:02 PM
TurboA32's Avatar
has anyone done a compression test on a vq30de when it was out of the car? If so explain what exactly what is needed so I can see what I'm doing wrong
Old Nov 28, 2012 | 02:08 PM
[s3]'s Avatar
Same as if when it was in the car, aside from cranking it yourself
Old Nov 28, 2012 | 02:56 PM
TurboA32's Avatar
No help but thanks let me explain my end a little better....I have a battery, jumper cables, starter, a piece of transmission bellhousing where the starter goes and a flywheel. Made all the connections which consist of connecting the jumper cable negative to the body of the starter and the positive jumper cable to the positive on the starter then connecting the other ends to the battery. Then i took the switch on the starter and touched the positive and then I dont get anything but a click?? The engine isnt turning over any thoughs??
Old Nov 28, 2012 | 05:48 PM
nsnrider's Avatar
sounds like you are energizing the starter solenoid but the starter itself is not getting any power. If the starter is in working condition, try giving power to the other terminal while keeping the negative cable grounded to the body of the starter.
Stupid thought but make sure the engine cranks over by hand before trying with a starter.
Side not, you will not get very accurate compression readings on a cold engine. Normally you want the engine warm to do a good compression test. Have you tried a cylinder leak down test?
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
