my new rad is cooking the fan assembly
Old Dec 8, 2012 | 11:35 AM
saig's Avatar
After installing new rad, there is plastic burning smell rising between rad and the fan assembly. Temp gauge shows normal, needle is horizontal. Is this normal?
Well. Rad is TYC 1752 from Rockauto. Someone here said it uses koyo core. IMO, it is not, there is no logo whatsoever on unit, box says made in china.
Old Dec 8, 2012 | 01:19 PM
Nealoc187's Avatar
SLOW
i have a very hard time believing the radiator is getting hot enough to burn the plastic material of the radiator shroud. i think you may have something else causing this.
Old Dec 8, 2012 | 01:57 PM
asand1's Avatar
Exhaust is more likely. Are you running headers? Heat shield?
Old Dec 8, 2012 | 03:10 PM
saig's Avatar
Hook it up with OBD II (live view), coolant temperature is shown 187-190F. So the rad should have the same temp as well. The old rad sprayed coolant onto heat shield (aluminum) so I did give it a wash. It could be from that.
Old Dec 9, 2012 | 06:28 AM
njmaxseltd's Avatar
Typical new painted part getting hot first few times smell?
Hot water isn't going to burn anything aside from your skin...
Miket2006
Mar 1, 2021 03:55 AM
atriuum
Sep 28, 2015 01:19 PM
Noela
Sep 26, 2015 08:22 AM
RWCreative
Sep 21, 2015 11:01 AM
