Maxima Stops While Driving
Old Dec 13, 2012 | 06:42 AM
fface40's Avatar
I have strange problem.
Car automatically stops while i am driving.
When it stops Car automatically applies the break and comes to halt.
Breaklight and Check Engine light is on.
Steering Wheel was real hard that even to reach side of road i have to use real force.
Once car comes to halt just turn off the key and restart the car then it just goes fine.
Above scenario can be reproduced
If I switch off the A/C or Heater and drive for 3-4 mins.
or
If I drive at 80mph for 3-4mins.
please help me on this.
Old Dec 13, 2012 | 06:56 AM
asand1's Avatar
Its called the engine dying. When the engine dies all the dashlights will come on. There will be no power steering or power brakes. You will have what is called ingine braking, where the drag of the dead engine causes the car to decelate.
Old Dec 13, 2012 | 07:37 AM
maxima2fst4u's Avatar
just junk it...thats what imma do to mine lol well part it out first then junk her probley
Old Dec 13, 2012 | 07:45 AM
Amerikaner83's Avatar
this.
Is your car overheating? What's your temp gauge look like?
Since you can replicate it so easily I don't think running out of gas is your problem...but do you make it a habit of filling up after the low gas light is on? Fuel pump could be weak.
Old Dec 13, 2012 | 08:32 AM
[s3]'s Avatar
Overheating
Old Dec 13, 2012 | 07:03 PM
fface40's Avatar
No, Temp Gauge needle is in middle.
I was able to reproduce that stalling only on above said particular scenarios. otherwise car runs with out hitch.
if i drive it on 70mph or below / switch on A/C or Heater then i wasn't able to reproduce problem, i think because of this nature i wasn't noticed this issue for long time.
Old Dec 13, 2012 | 07:41 PM
styliztik's Avatar
go get your cel light checked and see what it's for, and fix it. your ecu is shutting the engine down for a reason - to protect it.
Old Dec 14, 2012 | 02:37 PM
cashoit's Avatar
Sounds like your idle air control valve (IACV) has crapped out to me. Do a SEARCH.
There is a **** u can adjust that will keep the Throttle body cracked open a bit to allow air into the engine, thus keeping the engine running.
It sounds like the IACV isnt opening once the car has come to a stop
Old Dec 15, 2012 | 04:46 AM
Trini Boom's Avatar
. And why is your brake light on? Are you low on brake fluid??
Old Dec 15, 2012 | 12:38 PM
fface40's Avatar
Today I checked the battery GND terminals for connectivity (based on just wild theory, I checked the electrical) and found out that GND terminal was loose, once I fixed that in garage everything working fine so far and I haven’t tested the 80mph 3-4 mins drive once I do that I will update.
Some people asked to change alt and some other asked me to clean the fuel line but at the end the problem lies in totally different place. Nice learning on this process.
Thanks all of you folks.
Old Dec 15, 2012 | 12:41 PM
fface40's Avatar
No, Break fluid is no low, but I don't know why it was on.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
egali045
Aug 16, 2015 01:19 PM
egali045
Aug 5, 2015 09:02 AM
yat70458
Aug 3, 2015 01:16 PM
