just did a 5speed swap need help
Old Jan 5, 2013 | 09:36 PM
P0tter7's Avatar
i did a 5 speed swap on my 97 max. it went well i been driving it and have no problems exspect for the CEL codes. 1 major question is, are the ecu connectors the same from auto to maunal. and is ther a way i can use my auto ecu without the codes? if anyone could help would help me out big time. im going to get the codes its leavin on monday. i didnt have time to right them down today. thanks guys.
Old Jan 6, 2013 | 07:03 AM
bksmax11203's Avatar
Unfortunately, the only way I know how to get rid of the codes is to get a manual ecu from a 95-98. The codes you should be getting would be for the auto tranny.. any other codes would have to deal with a different area of the car, but def tranny codes. Best ecu to get is from a 95 as there no speed limiter as well as no egr so if you choose to delete your egr, you can do so without codes.
Old Jan 6, 2013 | 09:13 AM
CallMeThatOneGuy's Avatar
the 95 SE has no speed limiter, but that goes for all SE's. The GXE limits at about 117 and the GLE is around 100 if I remember correctly. And there is an egr, but it's mechanical and easy to just block off.
Old Jan 6, 2013 | 08:16 PM
demon_maxima's Avatar
im not sure thats correct. i had a GLE auto that i topped at 135.
Old Jan 8, 2013 | 08:43 PM
P0tter7's Avatar
i ****in seen this to late i already ordered a 97 ecu. i wish i read this sooner cause i woulda went with the 95 and blocked off the egr. im gettin tranys codes and i got some other code. i clearled them today and ima see wat comes back up tomrrow. and when the ecu comes in ima swap it. wat do i gotta do electraily in order for no codes. is there any rewiring that i need to do or can i just hook up the ecu an be straight( i have already done the reverse lights and i have set up the other to wires in the reverse switch on the tranny(they are so when the tranny is in N the current is connected) i hooked them up to the P/N switch in the harness so i dont have to push the clutch pedal in to start it but it has to be in N to start cant be in any gear. if there is any wireing could u plus let me no. my car needs to be inspected like 2 months ago
thanks
Old Jan 8, 2013 | 08:45 PM
P0tter7's Avatar
and isnt there a way i can get rid of the speed limiter?
Old Jan 9, 2013 | 05:34 PM
vqzengel30's Avatar
http://www.vqpower.com/v3/content/speed-limiter-removal
Did it to mine no problem but CEL
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
