Clanking noise??
Old Jan 11, 2002 | 09:41 AM
fmacdowell's Avatar
Clanking noise??
Hello my fellow Maxima enthusiasts. I have a dilemma?? I have a 1995 Nissan Maxima SE W/116K miles. I'm getting a clanking noise as I start from a dead stop going from 1st to second and some times 3rd gear. It dissipates once I'm in cruising speed. It sounds like it's coming from the front (right) passenger side underneath the car. I can hear a rattle and clanking noise, it sounds like pipes hitting each other. I'm wondering if anybody has experienced this problem. I hope I've explained enough. Any suggestions or ideas is greatly appreciated. Thanks for all those who helped me previously on my Injector problems. I also wanted to add, the other day while driving, my front end would start to shake and pull right, it felt like my tire was going to fall off. I pulled over checked my lug nuts all was fine. However, as I continued to drive there was no more shaking and pulling??? I'm lost Thanks
Fred
Old Jan 11, 2002 | 09:43 AM
Sprint's Avatar
have you done anything to your suspension recently? upgrades? or any accidents?
Old Jan 11, 2002 | 11:24 AM
njmaxseltd's Avatar
Lose tire-rod end?
Old Jan 11, 2002 | 08:52 PM
drew01182's Avatar
OH MY GOD! I'm having the same problem. I have an auto and the same thing is happening when I accelerate, especially from low rpms. I have about 114k miles on my car. The noise seems to be coming from passenger side of the engine by the time chain compartment(?), right above the belts. When I put my hand there and rev the car, I can feel the something hitting against the side when the clanking noise occurs. Like you said, at cruising speed or when accelerating at high rpm's I don't hear it. It also seems to be worse/louder the colder the weather is. When I start the car in the morning, it's LOUD but as it warms up, it runs quite when idle.
Any help would be greatly appreciated!!!! I'm really don't want to take it to the dealer because I honestly don't trust them.
-Drew
Old Jan 11, 2002 | 09:19 PM
KWheelzSB's Avatar
-Drew
Possible culprits:
-Bad engine mount
-Loose or broken bolt on Y-pipe or Catalytic converter
-Also check for loose cat-converter or exhaust heat-shields
Btw, you've distinguished your problem from "fmacdowell"'s, in that you can replicate the noise while at a standstill, by manipulating the throttle from under the hood. This eliminates three other possibilities that he may face if he cannot do the same: suspension, steering, or half-shaft (transaxle) problems.
Good luck!
Old Jan 11, 2002 | 10:01 PM
drew01182's Avatar
Found some good info after doing a search. Here's a pretty good thread on what seems to be the same problem:
http://forums.maxima.org/showthread....5&pagenumber=1
A TSB is mentioned for '95 Maximas...
Service Bulletin Number: NTB96086A
Bulletin Sequence Number: 139
Date of Bulletin: 0006
NHTSA Item Number: SB613975
Make: NISSAN
Model: MAXIMA
Year: 1995
Component: ENGINE:TIMING GEAR AND CHAIN
Summary: THIS BULLETIN CONTAINS A NEW TIMING CHAIR TENSIONER, TENSIONER GASKET AND GUIDE IF A RATTLE OF EITHER SEVERAL SECONDS OR CONTINUOUSLY IS HEARD COMING FROM THE AREA OF THE TIMING CHAIN COVER WHEN THE ENGINE IS STARTED AFTER A COLD SOAK FOR VEHICLES WITHIN CERTAIN VIN RANGES. *TT
I searched the NHTSA site and also found the same TSB for '97's. I'm pretty discouraged that a fix will run around $1800, at the dealer of course. This really sucks.
Old Jan 11, 2002 | 10:29 PM
NISMOPower's Avatar
same exact thing is happening to me too.......
Old Jan 11, 2002 | 10:31 PM
NISMOPower's Avatar
but i'm a 97 GLE Maxima with about 75000 miles and drives hard....(it's kinda hard not to with a Maxima for me...heehee)
Old Jan 12, 2002 | 05:58 AM
KWheelzSB's Avatar
. . .FOR VEHICLES WITHIN CERTAIN VIN RANGES. *TT
I wonder if anyone has the VIN# ranges this TSB applies to (?????)
Old Jan 12, 2002 | 06:10 AM
sunnyb32's Avatar
same prob!!!!!
yo!!! i cant belive it i have the same prob too!!!! although i 've had it for a long time now since i bought my 95gle in 1999 it's always been doing i really dont mid much i've had it checked and numerous ppl say its noting
Old Jan 12, 2002 | 07:09 AM
NISMOPower's Avatar
does anyone have a solution for this or know what the problem is?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
