Problems at Start up
Old Jan 11, 2002 | 11:37 AM
Capitone's Avatar
I've noticed it a few times in the last 2 or so months, but now it seems to happen more often. I start the car, RPMs jump up as normal, but dip shortly after sometimes to the point of cutting off. Now if I see this happening, giving it a little gas will at least keep the car on until my RPMs level off to normal....Any ideas what the problem is?
Old Jan 11, 2002 | 12:06 PM
NotNew!!NewSN!!'s Avatar
first like always, clean throttle body, but in my opinion, its ur idle air control valve, if not then throttle position sensor, look up some of my posts i did about this, becuz i had same exact problem except mine wouldnt even start up, it would stall right after i started it, changed idle air control valve, and wah-lah, gone, this seems to be common occurence.
Old Jan 11, 2002 | 12:16 PM
Capitone's Avatar
Thanks for the directing. What topic should this thread be under....
Old Jan 11, 2002 | 12:22 PM
max808's Avatar
How much fo rthe valve?
How much did you pay for the valve? and do you have a part number? Thanks.
Old Jan 11, 2002 | 12:26 PM
95emeraldgxe's Avatar
you kno its funny, all of my friends that have kept their maxima's stock dont get these problems.....but me on the other hand =( - and i only have one "real" performance mod
Old Jan 11, 2002 | 12:29 PM
1st97SE
Re: Problems at Start up
I had the same problem, I thought it was b/c my car didn't like the cold. It was not happening in the summer, just in the cold of winter. Well, I took everybody's advice and cleaned out my throtle body. Problem solved, I start up and idle is as steady as brand new. Here's the link:
http://motorvate.ca/
Good luck
1st97SE
Old Jan 11, 2002 | 12:36 PM
fred97gle's Avatar
I cleaned the throttle body and the butterfly plate. It had some black sticky build up on it that made the plate stick after sitting for a while. It is real easy to clean and took me about 30 minutes total. Noticed a huge difference in throttle response after I did it.
Old Jan 11, 2002 | 12:47 PM
well part is about 110 i think and close to 200 with labor, but 50 for me cuz that is my deductible on my warranty, which it was coverd by, im sure u could find a way to do it urself or get the part from a junk yard, and about mods f ing it up, this was when my car was stock, but like i said always try throttle body first, but i think its iacv
Old Jan 11, 2002 | 01:12 PM
Scruit's Avatar
U wanna try me young boy?
Can we make this an FAQ item? Or at least a sticky during winter. This seems to be very common when these cars get cold...
Old Jan 11, 2002 | 01:23 PM
Capitone's Avatar
Re: Re: Problems at Start up
Good luck
1st97SE
Great! I'll give it try. Appreciate the input Fellas!!
-Capitone Out-
Old Jan 12, 2002 | 10:00 AM
taeMAX97's Avatar
NO WORDS......... just clean your TB please.~~~~~~~~~~~
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
