99 max installing FSTB(vibrant) why don't I have to cut the bracket?
the tiny driver side bracket thing, I didn't have to cut anything, it just went right in, look here
http://communities.msn.com/mycarniss...ma/maxima.msnw
did I get the wrong FSTB?
Originally posted by araffio
why would you have to cut anything???
Originally posted by JUDE
I just got my FTSB today for my 99. So if I understand from previous posts, since its a Courtesy bar, I don't have to worry about the bracket, right?
I think it's your guys' cars that are different in not needing to cut the bracket. I bought my Courtesy 5th Gen FSTB from Sterling99SEL, who didn't like the fit, and he bought a Courtesy 4th Gen bar instead. He DID have to cut his bracket, but he sent me a picture of it and the bracket on his car looks different from yours and sits higher. It's like an inverted Y squished down onto the strut, and looks like it would almost certainly interfere with that FSTB, since the C-bracket on the Courtesy FSTB looks almost identical.
I'm guessing then that the bracket is one of those mid-production run changes manufacturers sometimes make.
Mystery solved!
Mystery solved!
Re: I guess that's the difference between..
Originally posted by 1MAX2NV
plain 99 and the 99 SEL
-Cyrus
ok, I think it has to do with early & late 99 model, my early 99 model doesn't have the big bracket thing that late 99 models have. Take a look madd max's late 99 & my early 99
late 99 :
http://community.webshots.com/storag...upQZYCs_ph.jpg
http://community.webshots.com/storag...IjkUJTN_ph.jpg
early 99(mine):
http://community.webshots.com/storag...xeeUdyz_ph.jpg
http://community.webshots.com/storag...VNpCAsu_ph.jpg
http://community.webshots.com/storag...vxkhlmb_ph.jpg
late 99 :
early 99(mine):
Originally posted by Synki
Yep. I have a late model 99 GXE and have the braket there. I have test fitted a FSTB and realize i had to cut and never ended up getting a FSTB since i didnt want to cut it
j/k
I think it probably has to do with production date?
and not purchased date? Who has the earlist production date for a 99? Mine was made in 12/98. I bought it 03/99.
Re: I think it probably has to do with production date?
Originally posted by costcowholesale
u still don't have it?? you're afraid of cutting the bracket there & not using nitrous :laugh
j/k
j/k
I have it, just havent installed it yet. I need to fix the dremel.
Re: Re: I think it probably has to do with production date?
Check the plate that's on the door jam when the driver door is open.
I purchased mine 10/98 so mine gotta be one of the earlier ones. How do I check production date?
dank4us
34
Jun 10, 2024 03:45 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
