Car stalling ... No I didn't search.
Old Mar 10, 2013 | 01:47 PM
shadhorne's Avatar
hello im a noob and this question may have already been answered but I couldnt find it. Anyway i have a 5 gen maxima and last night i was going up a hill and my car died but it started back up a few minutes later and i didnt think anything about it because it has been doing it but not regularly. So today i was pulling into a store and it died and after i got it started the cel came on so now im worried because its my work car so can anybody help me because ive searched and i dont know if its the fuel pump, fuel filter, crankshaft sensor or what. And also sometimes before this happen the car would slow down while i was driving and then pick back up again any help would be greatly appreciated.
Old Mar 10, 2013 | 01:49 PM
rebelhell's Avatar
Go to any major auto parts store and have them read your codes (Advance Auto, AutoZone, etc.) and then come back to the forum. It could be any number of things at this point. The codes will help narrow it down a LOT.
AND WRITE DOWN THE NUMBERS!
george__'s Avatar
Do you have a OBD reader?
Get one or get the car to a store that can read it for you and see what the obd reader tells you
Old Mar 10, 2013 | 01:52 PM
MaxFiyah's Avatar
what they said ^ but you should buy one i had mine for a few years and it always come in handy def worth the money
Old Mar 10, 2013 | 02:05 PM
shadhorne's Avatar
ok thanks will do but im a little afraid now since it just died while i was driving normal speed and the nearest shop is about 10 miles away
Old Mar 10, 2013 | 02:19 PM
rebelhell's Avatar
AAA is always good to have too.
Old Mar 10, 2013 | 02:26 PM
Ghost_54's Avatar
I'll put my money on the CPS sensor.
Have you found that the stalling issue only occurs once the engine has reached operating temp? I found this issue happened when my CPS sensor went on bank2, at first I received no SES light to indicate the issue but after a view times on went the SES ... So my best guess without knowing the code you are throwing would be you have an issue with the CPS
Old Mar 10, 2013 | 02:51 PM
shadhorne's Avatar
Yea when its at normal temp it does it
Old Mar 10, 2013 | 03:10 PM
Ghost_54's Avatar
Now you need to know the SES error code mine was for bank2 P0345 on my 03 Max.
What year is your Max?
Old Mar 10, 2013 | 03:25 PM
shadhorne's Avatar
2003 also
Old Mar 10, 2013 | 03:44 PM
Ghost_54's Avatar
Well then you really do need to get the code read the guys have suggested a couple of places that can do it for you if you do not have a code reader. The codes for the CPS are
Bank 1 = P0340
Bank 2 = P0345
Either sensor is very easy to change as it is held in place by a single 10 mm bolt unclipping the harness is done by pushing the green tab downward until it unlocks, then uplug take care in gently extracting the CPS sensor and then replace.
Up here in Ontario the CPS sensors sell for approx. 80.00 a piece you most likely only need to replace the one throwing the code ... DO Not get an aftermarket sensor get a real OEM replacement to afford other issues.
Old Mar 10, 2013 | 03:49 PM
shadhorne's Avatar
thanks for the advice hopefully its nothing major
Old Mar 12, 2013 | 05:14 PM
shadhorne's Avatar
well it was the camshaft sensor and got it changed out so hopefully the problem is fixed
Old Mar 12, 2013 | 10:02 PM
gapboi210's Avatar
So it was stalling before and you "didn't think anything of it?"
Lakersallday24
Jun 16, 2019 01:35 AM
Turbobink
Aug 15, 2015 07:20 AM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
