Sponsored by:
Sponsored by: CARiD
3.5 swap and keep 4at?
Old Mar 12, 2013 | 09:16 AM
CallMeThatOneGuy's Avatar
I'm working on a 3.5 swap and about to drop ot in the car soon. I decided to keep the 4at and i'm looking into tq converters. I don't think a high stall is exactly what i want and everyone seems to be going that route. Will a tq converter from a 5at do the trick or do i have to go aftermarket?
Old Mar 12, 2013 | 10:19 PM
ajcool2's Avatar
Go aftermarket. Edge Racing is well known for their tq convertors.
Old Mar 13, 2013 | 04:31 PM
i'm not going to be putting down a ton of power i just need something semi-reliable for a relatively cheap price. will a 5th gen work?
Old Mar 13, 2013 | 08:05 PM
MaximaRated's Avatar
Im also goin the same route and i heard level 10 does good tq converters
Old Mar 14, 2013 | 06:44 AM
FastnFuriousMax's Avatar
How much does an after market tq converter cost?
Old Mar 14, 2013 | 08:51 AM
all of them tha i saw were from 550-1000 so I would rather have someone tell me if a newer model converter will fit on a 4at. or maybe an altima 4at converter?
Old Mar 15, 2013 | 06:37 AM
Maxidave?'s Avatar
completely unrelated and i didnt want to start a new thread, but is there a 3.5 swap into a 95 max write up and if you could point me to the right direction? i used the search but i find a bunch of other random ones
Old Mar 15, 2013 | 08:41 AM
http://forums.nycmaximas.org/showthread.php?t=19270
google works good too. only 3 or 4 kinds of cars would do a vq35 swap so if you searched you would find it..
Old Mar 19, 2013 | 09:53 PM
So nobody has any knowledge on this? Anything about the altima transmission? Anything? This is kind of disappointing considering the amount of knowledge on this forum..
Old Mar 19, 2013 | 10:07 PM
Fakie J Farkerton's Avatar
^^This. :P
Old Mar 20, 2013 | 07:36 AM
grey99max's Avatar
LandShark has Cosworth
In that case, why change the torque converter? All 4AT stock converters are about the same - stalls around 1200 RPMs - and if you're not going racing, why bother?
If you want a high-stall converter, then it's Edge, Level 10, or IPT. I've had Edge and IPT, and my last one from IPT is built for a hard-stall at 3000. Works fine for street use, too.
Old Mar 20, 2013 | 08:54 AM
I was told that the stock 4at converter would never hold up to a tuned 3.5 with minor upgrades. And edge racing is quite expensive seeing as how i could 5mt swap or something. I'll just keep looking around til i get enough money or i'll find a 5at converter and try it
Old Mar 20, 2013 | 09:36 AM
grey99max's Avatar
The 5AT converter probably won't fit (with Nissan, that's a guess) but from personal experience you can race a cammed and SSIM 3.5 engine (with 150-shot of nitrous) with a 4AT and stock torque converter and do quite well. The 4AT transmission is the weak point - I went through a lot of them - the clutches and bands aren't up to it. I wanted to launch at higher RPMs so I first went to Andre at Edge and got a 2800-stall converter built, which worked fine on the street and highway.
Old Mar 20, 2013 | 06:07 PM
I see that all makes sense. I'll probably go lsd and just do this then. Thanks for a good reply and a uselful answer
Old Mar 21, 2013 | 07:35 AM
grey99max's Avatar
You're welcome - any forum is full of rumors and opinions, mostly wrong. I only post details about things I have personally done - details won't apply to everyone, but at least I know it worked for me.
One launching trick I remember from the stock converter days is that you lock the brakes, tap the throttle hard and back off to app. 1000, then when it's time to launch you smack the throttle pedal about half way down - wait till the car gets moving and gradually roll into the throttle up to WOT. This keeps the ignition advance up higher and gives more midrange power. Going WOT makes the ECU revert to the standard advance and slows you down. This takes some practice but works well on the 3.5 - which has lots more low-end grunt than a 3.0.
Old Mar 21, 2013 | 07:50 AM
Are you 100% sure you want to stay auto?
Old Mar 21, 2013 | 08:20 AM
i actually noticed the same thing on the 3.0 when i brake boost^^^
And yes I'd rather just stay auto at least until I have a second DD. I can't have my car down for days or weeks trying to tackle 2 projects at once. Maybe eventually I'll go 5 speed, but no time soon.
Old Mar 21, 2013 | 08:21 AM
unless you can get me swap components and a rebuild kit for my extra trans for $100? haha
Old Mar 21, 2013 | 08:25 AM
ABIGBRAIN's Avatar
One launching trick I remember from the stock converter days is that you lock the brakes, tap the throttle hard and back off to app. 1000, then when it's time to launch you smack the throttle pedal about half way down - wait till the car gets moving and gradually roll into the throttle up to WOT. This keeps the ignition advance up higher and gives more midrange power. Going WOT makes the ECU revert to the standard advance and slows you down. This takes some practice but works well on the 3.5 - whick has lots more low-end grunt than a 3.0.
This is the same technique I use at the track with my 99' auto I30. I pull consistent 2.22-2.24 60 foot times. Street tires @ 22 psi, SRI are the only mods. Race weight with me in the car is 3405 pounds.
Andy
Old Mar 22, 2013 | 01:02 PM
Andy
auto 3.0 i30??
Old Mar 22, 2013 | 02:45 PM
ABIGBRAIN's Avatar
auto 3.0 i30??
Yes
Old Mar 22, 2013 | 11:25 PM
ABIGBRAIN's Avatar
3.0 at work pic was taken at .515.on the clock system ..... .0019 before I crossed the start beam.
Old Mar 22, 2013 | 11:32 PM
ABIGBRAIN's Avatar
Old Mar 23, 2013 | 11:31 AM
ABIGBRAIN's Avatar
BYE run
Old Mar 24, 2013 | 11:27 PM
wow nice^^ I'm probably going to go aftermarket and play around with my options for a little bit. Hopefully save up some money for the rest of the drivetrain swap and possibly the MS PnP.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Unclejunebug
Apr 2, 2016 05:42 AM
09maxshawn11
Sep 30, 2015 10:28 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
