Motor Mounts and Flex Pipe
Old Mar 14, 2013 | 04:01 PM
Noela's Avatar
I have been hearing some rough noises from my engine area for a while, and suspected it was exhaust related.
My mechanic told me the flex pipe (braided section) is broken. And he attributed it to the fact that my front engine mounts are loose and must be replaced.
Do I need to replace all mounts now that some of them have begun to go bad (car has 191K, mounts are probably still stock).
Any place to buy the mounts? How about the braided flex pipe?
Thanks - Noela
Old Mar 14, 2013 | 04:49 PM
kingofny1997's Avatar
Have dealt and heard About these issues....
1st check or change-sway bar end links in front
2nd check - front and rear motor mounts usually it's those that need to be changed and if you have 191k might as well change if your going to stay with the car..
video would be great tho it could be different things
ROCKAUTO.COM IS HEAVEN!!!! Stand by them
Also since your in jersey might AS Well PM Djfrestyl you'll get hooked up
Old Mar 14, 2013 | 04:57 PM
Also just asking if his flex pipe is damaged, is their anything you can replace it with that will give you so boost (HP)
Old Mar 14, 2013 | 05:20 PM
rebelhell's Avatar
OBX or Cattman Headers?
shilov
Feb 19, 2024 09:40 PM
lrb6805
Sep 17, 2015 04:49 PM
vball_max
Sep 17, 2015 10:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
