6 Gen Climate Control FSM Manual section?
Old Mar 19, 2013 | 12:59 PM
QwikKota's Avatar
If anyone has the climate control section for the 6th gen that would be greatly appreciated. I mainly just need to know the low and high side pressures for charging my system. Thanks.
Old Mar 19, 2013 | 01:42 PM
Costee's Avatar
The low side is the one with the bigger pipe (with hose) and a smaller lid; the high side has a smaller pipe with a bigger lid. The low side is the suction, and the high side the discharge.
Old Mar 19, 2013 | 01:53 PM
QwikKota's Avatar
Yes, I would like to know the low/high side pressures to charge to however.
Old Mar 19, 2013 | 03:24 PM
Costee's Avatar
You charge with the low side. That's why it's called suction.
Old Mar 19, 2013 | 07:11 PM
QwikKota's Avatar
I'm sorry, but I believe you have a reading comprehension problem. I needed to know the exact pressure to charge to. I purchased a manual, it is 142psi at 77°F outside.
Old Mar 20, 2013 | 01:18 AM
Costee's Avatar
Now I know why this thread has received no response from forum members.
Old Mar 20, 2013 | 07:40 AM
QwikKota's Avatar
Please enlighten me. I asked if anyone knew what the pressure specification was for charging my system. You replied with notes on which line was for what purpose. That is not what I asked. I know which line to connect to, I have a set of manifold gauges. The ports only allow you to connect to the correct ones.
Not many people work on their own a/c, and very few know the exact pressure to charge to. That is why there has only been a few replies.
Old Mar 20, 2013 | 08:20 AM
DrewSER's Avatar
A quick look at the index suggests that this may be your section..
http://www.nicoclub.com/FSM/Maxima/2006_Maxima/atc.pdf
Old Mar 20, 2013 | 08:34 AM
DrewSER's Avatar
Just noticed you have a 2007. I doubt its different but here is the 2007 Max FSM..
http://www.nicoclub.com/FSM/Maxima/2007_Maxima/
Old Mar 20, 2013 | 09:57 AM
QwikKota's Avatar
Doh, I just bought a manual, but it was only $4 and all one file. Thanks a lot for actual helpful information! Yes, I am sure it is the same for 2004 to 2008.
MikesChevelle
Mar 2, 2021 11:32 AM
asianstyle
Aug 24, 2015 08:29 PM
