Safc2 problems?
Old Mar 22, 2013 | 05:58 PM
dnice02's Avatar
Safc2 problems?
So i finally got around to wiring up my Safc2. I started the car an the A/f ratio is at 10.2-10.6 @ idle. I also have a cel. I tried to rev the car and it won't rev past 2200 rpm. Why is this happening? I cut the MAF wire, and wired the sensor side to the afc.That was my understanding from others install. Also i think that i may have the arrow, that's in the Car select menu in the wrong direction. I'm not sure which way its suppose to go. I tried both ways and nothing changed. Am i suppose to do a throttle re-learn after installation? Thanks in advance.
Old Mar 22, 2013 | 06:03 PM
nishfish871's Avatar
Is your in/out settings 1 to 1? Dont need a throttle relearn. Reset to safc and start over.
Old Mar 22, 2013 | 06:07 PM
dnice02's Avatar
Yes In/out is 1 and 1
Also which way is the arrow suppose to be up or down?
Old Mar 22, 2013 | 07:17 PM
Up!
Don't worry about the 4in/4out that's for a different MAF.
http://www.vqpower.com/v3/content/sv...1995-99-maxima
It will take 2 or 3 starts for the ecu to figure out it is receiving the correct signal, once you have it setup correctly.
Old Mar 23, 2013 | 10:02 AM
dnice02's Avatar
Thanks nishfish871. I have yellow wire going to the wrong aide, and I don't even have the white wire hooked up. once the rain stops here i'll go give it another try.
Old Mar 23, 2013 | 05:05 PM
Brl24's Avatar
Noob question here.
Do you need a wide band sensor to read afr, or does the safc read it?
If it did I'm assuming it would from O2's? Would you consider it accuratly measured by their location?
Old Mar 23, 2013 | 10:15 PM
Originally Posted by Brl24
Noob question here.
Wideband unit and sensor. safc can't read afr, just alter it blindly.
Old Mar 24, 2013 | 07:35 AM
Brl24's Avatar
Haha, I figured that.
The best place for the WB sensor, if your doing just a single, would be in the y-pipe just after the collector correct?
Old Mar 24, 2013 | 09:27 AM
Right after the flex pipe
Old Mar 24, 2013 | 09:38 AM
Brl24's Avatar
10/4 thanks.
Old Mar 30, 2013 | 11:37 AM
dnice02's Avatar
So i finally got everything wired up correctly and all the initial settings in. Also going to install my LRMAF. Now my question is where do i start tuning? Hi or low settings. On the average I/H/nwp spacer modded car, about how much fuel needs to be added/removed across the board?
Old Mar 31, 2013 | 11:20 AM
NmexMAX's Avatar
dot dot dot ...
That's something your WB will tell you. Not a universal answer, all depends on each specific car. Lotta factors.
MAF size/injector size, etc.
Old Apr 5, 2013 | 11:40 AM
dnice02's Avatar
Ok can someone please tell me what I'm doing wrong. I've added up to about 7% fuel all across the board hi and lo and I'm still running lean as hell. Can I have a bad safc? It wasn't this lean until I installed the unit. Especially at wot. It goes of the chart.
Old Apr 5, 2013 | 11:58 AM
Puppetmaster's Avatar
What data did you use to base the adjustments off of? How do you know it's lean? Posting the data will help us offer you feedback, because it's hard to know what is going on with no hard numbers.
Old Apr 5, 2013 | 12:23 PM
NmexMAX's Avatar
dot dot dot ...
MAF size, and in/out settings, AFTER you post the actual numbers.
Old Apr 5, 2013 | 12:44 PM
dnice02's Avatar
I have an arm uego wide band. Afr bounces around from 15:1 to off the chart. Sometimes it drops to mid 14's
Stock Maf. 1/1 in/out. I didn't install the lrmaf yet because of the conditions now
Old Apr 5, 2013 | 01:47 PM
NmexMAX's Avatar
dot dot dot ...
When does this occur? if it happens when you let off the throttle, that's normal. What does it idle at?
How about WOT, or near WOT, and normal driving?
Old Apr 5, 2013 | 02:08 PM
dnice02's Avatar
Idle is between 8-900rpm. Regular driving its in between mid 14's to high 16's. Half throttle and WOT go from 14's to off the chart. Gonna get a video in about an hour
Old Apr 5, 2013 | 02:43 PM
NmexMAX's Avatar
dot dot dot ...
AFR at idle... but yeah, looks like you've got some issues.
Old Apr 5, 2013 | 05:04 PM
dnice02's Avatar
http://s741.photobucket.com/user/r6r...4f419.mp4.html
Old Apr 14, 2013 | 08:17 AM
dnice02's Avatar
so I changed my MAF (oem) and disconnected the afc & the car is still running lean. What else can cause this lean condition? I'm going to check my wide band sensor here in a few to make sure that's not faulty.
Old Apr 15, 2013 | 02:29 PM
NmexMAX's Avatar
dot dot dot ...
Run an air calibration of it has that option, if not, check for intake air leaks.
Old Apr 15, 2013 | 09:14 PM
dnice02's Avatar
Aem uego don't have the calibration feature. It's calibrated from the factory.
Old Apr 16, 2013 | 10:40 AM
dnice02's Avatar
I did the sensor test and here's the results. Disregard the noise in the background. lol
Old Oct 14, 2013 | 07:57 PM
dnice02's Avatar
bumping an old thread. A/f ratio still goes lean under heavy throttle and sometimes at idle. What else should i check? can my timing be causing this?
Old Oct 15, 2013 | 07:03 PM
TriniSpeC's Avatar
I am running a 540i 3.5" maf with my in/out settings 1/1 and my a/f is around 15.0 at idle and wot im between 13.7-14.5 from 2000rpm to 7000
Old Oct 16, 2013 | 02:43 PM
NmexMAX's Avatar
dot dot dot ...
What size injectors do you have? How did you get your rev limit that high?
Mine ran lean as heck even with just a 3" MAF with 1/1 and Z33 injectors. Ran fine with 440's @ 1/1 and a 3" and 3.5", 4" required 1/17.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
