Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
AP Racing rotor
Old Jun 1, 2013 | 11:33 AM
JDMmaxima11's Avatar
AP Racing rotor
I currently have the AP racing BBK on the front and rear. I want to upgrade the front rotor to a bigger size. Would the front rotor from the 370z 6 piston setup work with my 4 piston caliper? Is the 370 brake setups compatible with the maxima?
Old Jun 2, 2013 | 04:06 AM
MrEous's Avatar
^ Jeff™
How would a larger rotor fit without getting a new caliper relocation bracket?
Old Jul 3, 2013 | 09:55 PM
00Lightsout's Avatar
yup!! you'd need a machine shop to make a new caliper bracket!! I've got the same AP setup
Old Jul 5, 2013 | 05:14 PM
oh... also you would need to run larger rims! currently 17" is the minimum size you can run with the kit, if you run a bigger rotor with a relocation bracket that pushes the caliper further from the hub center 17" rims are then too small. If u decide to run a bigger rotor and upgrade your rims, get lighter rims because the larger rotor will add weight and a larger but lighter rim will counteract that added unsprung weight! Lastly, if u purchase new rims check your offset and rim to caliper clearance or you'll be hit'n yourself in the face after all your purchases :-/
Old Jul 16, 2013 | 03:42 PM
So what if I just bought the 6 piston application that they have for the 370z? Wouldnt that bolt on?
Old Jul 17, 2013 | 08:16 AM
MrEous's Avatar
^ Jeff™
5th or 6th gen Maxima...no
7th gen yes
Old Jul 20, 2013 | 01:28 PM
word ^
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
MplsMadMan
Sep 11, 2015 07:54 AM
beerman1378
Sep 8, 2015 02:19 PM
