205 vs 215 tires
Old Jan 14, 2002 | 11:34 AM
Toffy's Avatar
205 vs 215 tires
Is it possible to swap 205 for 215's.
You can save a ton of money by moving to 205 from the stock 215 tires but Im not sure if that recommended. Comments.
Old Jan 14, 2002 | 11:59 AM
NYCe MaXiMa's Avatar
Re: 205 vs 215 tires
sure it's possible.... and you can do it if you want.. What rim do you want to do this to? the stock 16" SE rim? They will fit, but they will be a little more narrow... I am not sure about the money saving, to me, the 40-60 bucks you may save, is not worth it.... car will handle a bit worse, plus it will probably be easier to scratch the rim since there is less sidewall sticking out to protect it from the curb. I wouldn't do it.. but it's up to you.
Old Jan 14, 2002 | 12:03 PM
JSMax's Avatar
Sold
I switched my tires from the stock 205/55 16 to the 215/50 16 and have had no problems with handling, or torque steer. If you want to switch your tires, just make sure you keep the rotation distance (the distance it takes the tire to make one full rotation) the same. Any store that sell you tires should have this information. Also, ensure that for every size you go up your aspect ratio should go down. As i've said, I have had no problems and yes, I did save a tonne on $$$. One other thing... keep the speed rating or the tire the same or go up. NEVER NEVER NEVER go lower than the speed rating of the O.E. tire.
later
Old Jan 14, 2002 | 01:06 PM
DaEnigma's Avatar
hmm the stock tires on my car's 16's are 215/55/16 (GoodYear "Bad traction in wet and not so good in dry" RSA's).
Old Jan 14, 2002 | 01:36 PM
HPS's Avatar
HPS
I just put 215/55/16's (Yokohama A520) from 195/55/15 (stock GLE). I was thinking of 205s, but I was told that the speed ratio would change on my speedometer (since I was plus sizing). Also, 215s will give me a more comfortable ride and handle a bit better than 205s.
Old Jan 14, 2002 | 01:58 PM
Maxilicious's Avatar
225/55/16's
I wrapped mine with 225/16's and they were actually $8 cheaper.
Old Jan 14, 2002 | 07:28 PM
iwannabmw's Avatar
I wouldn't downsize from 215 to a 205 (unless for snow tires). If you shop around you should be able to find really good 215's for the same price, and you'll enjoy better performance.
Old Jan 14, 2002 | 11:22 PM
95emeraldgxe's Avatar
stick with the 215's
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
