Clicking sound when you push on brake
Hey guys!!
So for the last couple of days I noticed when I push on the brake, I hear a little clicking sound..fast though and it doesnt do it all the time...only when I first start it and engage in moving but after its been on,at a redlight or a stop sign, doesnt do it, all the time!
Kind of frustrating, does anyone know what it could be? I know there is a slight clicking on the shifter **** when you push on the brake but its not that.... Thanks guys!
I think you might be hearing when the brake lights turn on.
For example, next time in a safe area, press the brakes and carefully try watching for when you brake lights turn on. What you may be hearing is when electrical contact is made at the switch, or when the relay activates and turns on your brake lights.
I know my 1999 Maxima did something similar. I took comfort in it knowing my brake lights were working, and also could use it to time my braking and avoid certain scenarios.
I also hear that, but I think its for the gears. Ok, hear me out, whenever you press on the brake, (of course the first time) it also here the click by the gear shift area. That might be because its letting go some sort of gear so you can move the stick wherever after that. That's my opinion, but I could be wrong.
It never bother me one bit, I always look it as a new technology for maxima to keep us safe ! Instead of some person accidentally pull on the gear **** and shifting it to reverse or drive. Before that all happens, we have to press on the brakes !
Hey guys!!
That clicking sound by the shifter is the shift lock, it is enabled when your foot is not on the brake so that you don't accidentally throw your car into reverse while driving.
The click from behind/underneath the dash you hear is most likely the brake relay switching the lights on and off.
That little click is either electricity doing a small but fully contained spark inside the relay, or the contacts literally hitting each other. Either way, as I mentioned, it's completely normal.
If it really bothers you, try looking for the relay itself and maybe adding some sound insulation around it.
EDIT:
Here: This site has a pretty good image of the insides of a relay: http://www.glolab.com/relays/relays.html
I think you might have to live with it. Nothing is at fault here, it's just the design of all relays. There is a little electromagnet that gets energized, and pulls a mechanical switch towards it's contact area to complete a circuit.
EDIT:
EDIT:
RWCreative
Sep 21, 2015 11:01 AM
