1999 Maxima Rear humming/shaking
Hey just hoping someone can help me with my max, havent been able to diagnose the humming/shaking sounds comming from the rear end of my car. It only happens now and again when i am applying low pressure to the brake at low speeds. 20km/hr or less. When it starts humming/shaking if i let off the break or press the break harder it stops. I have taken the tire off and the break pads are good. The rotors are a bit worn but there is no catching and realeasing when applying the break. The only solution i have seen is that maybe the caliper is seized..any feedback would be appreciated! Thanks
Sounds like warped rotors to me too. Don't waste your money having them turned, just buy some new ones. They aren't that expensive. Replace your pads too, and if you do the job yourself, the piston on the rear caliper needs to be turned clockwise for it to go in. It DOES NOT just push in like the fronts. If you can't get the piston to turn, or it will not go back in when you DO turn it, you need a new caliper.
Just some foresight advice.
New rotors/Pads too thick for caliper...
So i ordered front and rear brakes (rotors and pads). When i went to put on the rear pads and rotor the caliper wasnt big enough to fit over the new brakes (too thick). I turned and compressed the caliper piston as much as it would go and it isnt the problem, its the actual caliper wont fit. im thinking my buddy gave me parts that dont fit. Also i couldn't get the bots to remove the front rotor off. Dont have a heat device, any other good suggestions to get these rusty/seized bots out. Appreciate any advice.
Re the front, the rotor doesn't bolt onto the hub, so not sure what bolts you are referencing. If you are having trouble with the bolts for the caliper and/or the caliper bracket, then soak them in something like PB Blaster overnight, then get a 1/2 inch breaker bar. Even better is an impact, if you have access to air tools. Good luck.
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
wingsfan24
Aug 15, 2015 07:35 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
