I Need a "Personal Light". Anyone?
I need an interior light bulb for my 96 SE. It's the courtesy light located next to the power sunroof switch. I wasn't sure if it was called a "map light" or something else, but the Maxima owners manual refers to it as a Personal Light (see picture)
The only writing on the OEM bulb is "Life 12V 10W"
I went to the auto parts store and could not cross reference it. I could find the same mount size, but it was only a 2W. Heck, even the owners manual has a blank space for the bulb type even as it had numbers for most other bulbs.
Can anyone offer a part number? I hope to avoid going to the dealer as I can only imagine what that would cost. I prefer to stick with incandescent, but I will use LED if there is a replacement that will plug right in.
Thanks in advance!
Thanks in advance!
Yeah that's the map light. Any auto parts store will have them, they're a ba9 socket bulb. Like 3 bucks a pair
If you go LED, you should know the polarity is reversed so you need an LED that has a 2 part connector so you can reverse the wires at the bulb end, fyi
The size listed for 96 map lights is 1895. They are a twist-in base (much like turn signal bulbs). Here's what they have on eBay for them (though they are all LEDs): http://www.ebay.com/sch/i.html?_odkw...5+led&_sacat=0
If you don't like LEDs, you could use a "warm white" color LED which emulates the color of an incandecent bulb.
Sorry to
you Mike
.The size listed for 96 map lights is 1895. They are a twist-in base (much like turn signal bulbs). Here's what they have on eBay for them (though they are all LEDs): http://www.ebay.com/sch/i.html?_odkw...5+led&_sacat=0
KabirUTA13
19
Oct 17, 2015 02:15 AM
pears
Sep 18, 2015 05:25 AM
0m3nc0w
Sep 11, 2015 05:21 PM
