automatic seatbelt problems>>
when i shut my car off and open the door, the seatbelt doesnt move so i cant get out. i have to turn the ignition back on and hold the door open for it to retract so i can get out. anybody know what's wrong? it's really annoying and embarassing. it used to do it every once and a while but would always fix itself. it's been like this for a couple of days now. could it be some fuses or something?
It may be your seatbelt tensioning/lock
...on the floor between the seats there appears to be a tensioner that tightens the cross-shoulder portion of the seat belt during high-speed maneuvers (i.e., hitting a big sweeper at high speed and powering all the way through, creating a lot of lateral g's or stomping on the binders during a high speed left/right). I noticed that the shoulder piece actually tightens down and feels tight across my chest and has caused the automatic shoulder retract to stay in the "closed" position when I shut the car off and open the door. I just adjust the seat a little backwards to take the tension off the belt and that seems to do it. I also remember another post somewhere on this forum about the retracts so you might want to do a search for that too. Good luck.
Re: It may be your seatbelt tensioning/lock
Jim---Mine does this too. I can be a psychic and I can tell that when that happens, you just went around a corner very (or somewhat) fast/hard. When I try to get out, the seat belts are locked. The solution is ver simple: Press te emergency lock to loosen the belt so it unlocks, then put it back in. Problem solved. Lesson learned here: Don't corner hard going into your driveway. :-)
Id hate to ressurect a decade old thread- but I have a prob where my seatbelt will not lower itself when I turn the car off, then open the door. I must open the door then turn the car off for the belt to work.
Tl;dr my belt has no power without the car in the on position
Dang, this thread is almost as old as the internet itself!
Yes, the seat belts have a lifetime warranty. Some dealers are A-holes about providing the warranty work.
The best thing to do if you have seat belt problems is to call a dealer and try to get a nice service rep.
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
