bose and amp
Re: bose and amp
Originally posted by njoph85
i have a 1997 se with bose. is it possible to keep the stock setup and add an amp to the system to make it louder?
let me know if you have any more questions...
Originally posted by dwapenyi
The main reason the PD-2 is more expensive is because it takes the line level signals of your BOSE HU and feeds them to your other sources. So, the signal is cleaner.
DW
DW
You know what? I thought he wanted to get an amp to drive other speakers. So you guys are both talking about adding an amp, and then using that amp to drive the existing bose speakers? I find that odd, the bose amps deliver enough power to the stock Bose speakers, and the bose speakers still don't quite have the ability to deal with the bass when the bose amps throw it at the 6.5" Bose speakers. I would imagine this situation would be worse with an external amp.
By the way, the PD-2 is still better because you don't have to deal with resistance mis-matches as you had mentioned earlier. The PD-2 takes care of all that.
Originally posted by Autofanatic
so does the one from sounddomain.com...as i stated above... the PD2 is just a nicer unit, definitely cleaner, but the $50 one from sounddomain did fine for me....
I respectfully dis-agree. At least on my stock bose system, my rear 6.5s were distorting mostly because they reached the limit of their excursion, a little bit before power was maxxed. I envy the 3rd gen Bose systems because they had 6x9s so they could handle more bass. Look at your speakers thru the trunk while your blasting, you'll see.
Of course this also depends on the type of music listened to as well. The speakers seem to be well matched to the amps in terms of power on most music that isn't bass heavy.
DW
DW
the reason the bose speakers distort during bass notes is from a LACK of power, not because they have 'enough' power from the stock amps... with a good power source, you can drive any speak harder and sound much better than with a small power source
DW
DW
Aha! That would explain the different observatins. Most of my music has alot of energy in the 40 to 80Hz range. I like my bass
I know I need a sub-woofer. Maybe one day.
DW
DW
i mean, it certainly is possible yours were maxing out...but i was able to push mine harder when i ran them to an external amp...of course, my intentions weren't to have the bose handling low bass, i high passed them at 150hz and they handle power beautifully. dont get me wrong, i ran them at full range for a while just to enjoy how much better the new setup was from stock
