P1320 , coil packs are less, than a month old
Less than a month ago, treated my 96 to new plugs and a coil pack set. I got this code even though the car isn't misfiring. Could the computer be throwing erroneous codes to make me dump more cash into it?
Don't have $600 for OEM, at least they aren't misfiring like the original ones. Does 1320 make the car run like crap? Replaced first o2 sensor 2 weeks ago, now bad. Granted timing was way off due to a bad camshaft position sensor which I just changed.
EDIT: The aftermarket ebay coil packs I tried before that threw the P1320 code within 2 weeks.
As long as you are using aftermarket coils, you will always have that code. If your existing coils are OEM and you have a misfire due to them, get a used set of OEM rear ones and leave the front alone.
please post continuing results
thanks
Could misfire code be a spark plug? It looks okay, but wasn't firing for a few weeks because I didn't think of checking coil pack connections. As a result, a lot of unburned gas went through it. Did clean it, but not sure if that was enough
I bought these because the description said "Hanshin", what I didn't catch is that it said "Hanshin-style" coil packs.
As soon as they came in I took one look through the plastic bag and saw "Made in China" and sent 'em back, ordered the OEM through a dealer online for around $90 each, not worth risking a code and poor performance to save a few dollars when these are one thing that will leave you stranded in a heartbeat if they are not up to snuff.
Most spark plugs will easily last 50k miles, highly unlikely that it is bad unless the tip is not gapped properly or the ceramic is broken, more likely that the coil is the issue at hand.
Bank 1 (firewall) coil packs are different front bank 2 (radiator) coil packs and cannot be swapped.
I have 5 Autozone paks in my 99 over a year and never got any codes. Used OEM can be hard to find especially in a pinch. IMO OEM new are overpriced. To this day Nissan is making a fortune on their own prone to failure design.
If this generation Max has an Achilles heel, this is it.
Found a hanshin that was floating in my trunk . No more misfire. I replaced all of them because I was getting random multiple misfires. It is a front one engine cover is back on minus one bolt. Credit card got hacked so I can't replace both oxygen sensors so my car would be code free.
99 coils are junk
I see that you list yours as a 99, hence your coil troubles. My 96 had no issues with coils (in 2 years), my 99 has had constant coil issues
Going to hit a yard. #4 keeps misfiring. Out seems fine on first puddle, upon acceleration, you can hear the skip. I'm playing musical coil packs with the old ones i have. Boss is gonna love me calling in late for this.
A word of advice on the autozone duralast coils . . . I replaced one about 4 months ago with duralast. It worked for a few months. Then started misfiring again. Tried two different duralast coil packs. Neither worked.
Went to JY and pulled two hanshins. Paid a total of $15. Worked like a charm.
The packs I pulled were of a 97 with 190k miles. But that made them 100k miles newer than the ones on my 96!
Of course this assume that the OP put in the OEM platinums or maybe iridiums....if they used copper then the plugs would be done after 30K miles.
ballerchris510
Sep 11, 2015 05:29 PM
