Addco RSB install
Addco RSB install
Recently I bought Addco RSB from ORG member and finally I had time to install them tonight. To my knowledge this RSB fits 97-03 Maxima, but I had to remove some material off of the U bolt threaded portion to fit the trailing arm width. Before trimming, It wouldn't slide/install correctly. the threaded portion of the U bolt couldn't get around the width of the TA. After trimming, I could get the bolt to fastened correctly with at least the nut thickness for thread engagement. The install took 1 hour included the u bolt tweaking. Pretty significant cornering improvement I must say.
Has anyone experienced this issue?
At high speed sharp turn, it does feel like the front end is oversteer but think this is more like driving habit and technique. Once I played with the timing of exit speed and steering movement and installed FTSB, it cornered the road much better. Next week would be replacing my leaky TA bushings and work my way up front for all the bushings, tie rods, and ball joints.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
the addco hardware apparently has this issue. I ended up getting a new u bolt with shorter threads and it was all good
