Got the Tomei air/fuel ratio gauge today...
Re: Re: Got the Tomei A/F gauge today...
Originally posted by thebigsadler
no. but i would like to see it..
Thanks for the hookup, Hogan (yo_its_ok).
it SHOULD have three wires (basedon other air/fuel gauges I've seen)
one is to the O2 sensor (blue)
one is for power (red - usually for the lighting)
one is for ground (black)
if there are more, let me know... but that's how they typically are.
Originally posted by yo_its_ok
use the supplied 02 sensor,
need to splice wiring into stock connector.
yellow goes into the cabin to amplifier to the A/F ratio meter.
Kev you may need to cut open the back of the pillar to fit the Tomei amplifier, and the wire is fairly short from the Amp to meter, and needs to calibrated to stabilize the reading.
I think confused bypassed the amp, I could be wrong.
I'll find out today.
Yellow goes into the cabin? I thought yellow should splice into the parking light source to light up the gauge at night?
How does the amp get calibrated?
Thanks.
Originally posted by BigDogJonx
Aight all this techy talk is confusing us poorer and uneducated people. What is this thing, what does it do, why you need it?
Basic questions
Basic questions
I need it because I'm going to tune the S-AFC and get close to 12.5:1 for my air/fuel ratio.
Here are some pictures:
http://wwwcsif.cs.ucdavis.edu/~chin/.../Maxima/tomei/
Okay Kev...here goes...
I believe your car utilizes a 3-wire OEM 02 sensor [my 4th gen uses a 3-wire OEM 02 sensor (courtesy of Brett) so I'm assuming your 5th gen does, too] that needs to be swapped so that means you have to refer to the diagram on the upper half of p8 of your booklet.
See the picture of the Tomei 02 sensor on p8? The wires on the sensor going from left to right are as follows -
1) Tomei 02 sensor ground (gray) - you connect this to one of the separate black ground wires thats included with your kit. Then you connect the ground wire to the negative post of your battery.
2) Tomei 02 sensor signal (black) - you connect this to one end of the orange subharness that's included with your kit (you can see from the diagram). For other end of the subharness, one wire connects with the gray signal wire that runs from the main harness (see p6). For the last remaining wire of the subharness, you have to splice into your OEM O2 sensor signal wire.
3) heater power (white) - you splice this with your OEM O2 sensor power wire.
4) heater ground (white) - you splice this with your OEM O2 sensor ground wire.
Now go to p6 of the booklet.
1) The red wire of the main harness goes to a 12V source (not constant, of course).
2) The yellow wire of the main harness goes to illumination.
3) The gray wire of the main harness, we've already discussed in the above section regarding the subharness.
4) The two black ground wires of the main harness go to the negative post of your battery. (After installation, you should have a total of 3 ground wires running to the negative post of the your battery.)
I believe that's it. Enjoy the Tomei, I know I have. =)
Thanks Jeff. Your writeup is what I deduced from going back and forth reading the other O2 setups. I knew the 1, 2, or 4 wire O2 diagrams weren't correct, but I wasn't 80% sure what the lower portion of page 8 meant. I knew one went to power, one went to ground, but I wasn't sure what "3000 rpm blah blah blah blah 3 blah blah blah" I figure it was 0-1 V above 3000 rpm?
The only other part I wasn't sure about was the yellow wire. Thanks for confirming that it's the illumination wire (splice with parking light source).
Any need for recalibration?
You know how Alex told you to splice all the ground together to make it look nicer? Can't do that.
Thanks a lot.
No problem, Hogan. Thanks for the gauge.
Thanks a lot.
Additional info from 4th gen... o2 sensor wiring harness. the harness to o2 sensor has generic wiring (black/white). check the fsm or peel back the tape before the harness to verify.
(t02 = tomei o2 sensor)
to2 white female end goes to nissan ecu = blue/yellow
to2 white male end goes to nissan ignition - red/black
t02 black goes to splitter goes to nissan nissan ecu white
grey wire from tomei harness through firewall into splitter.
What i did is cut the three o2 sensor wires and attached it to the oem harness.
Make sure to observe where the oem wires are tied down and replicate after. Dont just let it hang or you will fray the wires.
In cabin, like Calsonic says, use ignition on source (fuse box) for one and 12v illumination source (ie. ashtray light) for the other and 2 grounds.
If you have an exta port in your y pipe, forget the o2 sensor splice and just put it in there with the grey wire from amp.
I don't have an extra O2 hole and didn't want to drill one... you can thus, the big nut in the kit.
I did the right bank sensor. Ideally, you should have two gauges, one in each pipe/bank
I keep trying to get Hogan to give me his
Thanks Brett.
Which O2 do you recommend splicing into?
I don't have an extra O2 hole like you guys so I have to splice.
Thanks Brett.
Thank you Mr. BB. :-)
Kev, rear upper. Easiest to get to.
-I think I drank too much.
I did the right bank sensor. Ideally, you should have two gauges, one in each pipe/bank :-D I keep trying to get Hogan to give me his :-p
I'd like to have another Tomei for my other bank. HeheheheI can't use right bank sensor 1 like you guys (on pre-cat).
Thank you Mr. BB.
Thank you Mr. BB.
if you have an egt in one bank why not put the a/f in the other rather than at the cat?
Now that I think about it, I have the EGT hooked up to the front so I'm going to hook the Tomei to the rear. PERFECT!!!
Thanks a lot.
Thanks a lot.
My O2 wire colors are different (2 white, 1 black) for sensor on the left bank.
I'll have to figure out which is 12V and which is signal with a multimeter. Shouldn't be a problem.
Thanks.
Thanks.
Originally posted by mzmtg
HAHAHAHAHA!!!!!!!!
Even the writing on the guage has a Japanese accent ... you are either "rich" or "rean"
HAHAHAHAHA!!!!!!!!
I took the Tomei I had sitting on my desk when Nathan sent it to me, and figured out the wiring, but had to go meet DanNY for his H&R spacers. Went bowling and drinking, got home, wrote it all out, ready to do a small write up, then poof, Calsonic posted everything I wanted to say. Ignore what I wrote up there, I think I was sucking in too much exhaust fumes.
Actually, there is no letter "L" in the Japanese romanization of English words. However there is a letter "R" which is pronounced like an "L". That's why you always see L's replaced with R's in "Japanese-English" words.
I guess the same can sorta be applied to English speakers. Most can't pronounce Japanese words correctly & vice versa.
Sorry, this is getting to be OT.
As for the Tomei, the labeling may not be grammatically correct, but hey the darn thing works. =)
LoL, at least you were honest enough to pay me, or else I woulda hunted j00 down like a rabid dog :-)
Calsonic, no doubt. :-D
Could you check the General Forum for a Tomei question I had? Thanks.
Calsonic, no doubt.
Calsonic, no doubt.
but i was thinking...hmmm...ya know something was missing is that transaction..LOL
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
