Transmission problem
So I was on my way out of town today, about an hour and ten min on the highway when all of the sudden when I was pulling off the line at a stoplight my car wouldn't go. I shifted to neutral and back to drive and I was good. About 30 min later the same problem and my service engine light came on and now the A/T light flashes a few times and cuts off. What's happening?? I can't afford any major work right now.
Sorry to hear that, but don't worry just yet. First question is, has there been ANY work done to the tranny recently? Such as replacing fluid? And of course, try to pull the codes since you got a SES and let us know.
Using the wrong tranny fluid/dirty fluid/not enough fluid can cause such a problem. Or it might actually be the A/T temp sensor itself (located inside valve body). Did your car shudder at all when this happened?
Best of luck! And let us know what the codes are and as much details as possible.
If you have an FSM, page 173 in the EC section is where diagnostic for this starts. Im assuming you dont or you would know that "P0011: speed sensor" is the generic OBDII code, and that P0011 for a 5.5 gen is IVT Control. If I get more than 1 code I like to look through the diagnostic for each code and see if there is anything in common between the diagnostic procedure for each code
The procedure starts out with a bunch of short detections (probably not it) and moves on to part/sensor diagnostics, your first step should probably be to download an FSM, but here are the basics for the P0011 code:
Component Inspection
INTAKE VALVE TIMING CONTROL SOLENOID VALVE
1. Disconnect intake valve timing control solenoid valve harness
connector.
2. Check resistance between intake valve timing control solenoid
valve terminals as follows.
Terminals Resistance
1 and 2 7.0 - 7.5Ω at 20°C (68°F)
1 or 2 and ground ∞Ω
(Continuity should not exist)
CRANKSHAFT POSITION SENSOR (POS)
1. Loosen the fixing bolt of the sensor.
2. Disconnect crankshaft position sensor (POS) harness connector.
3. Remove the sensor.
4. Visually check the sensor for chipping.
5. Check resistance as shown in the figure.
Terminal No. (Polarity) Resistance Ω [at 25°C (77°F)]
1 (+) - 2 (−)
1 (+) - 3 (−) Except 0 or ∞
CAMSHAFT POSITION SENSOR (PHASE)
2. Disconnect camshaft position sensor (PHASE) harness connector.
5. Check resistance as shown inthe figure.
1 (+) - 2 (−)
2 (+) - 3 (−)
connector.
1 (+) - 2 (−)
1 (+) - 2 (−)
2 (+) - 3 (−)
So yesterday I took the car to the transmission shop and got the codes checked out. I let the guy who owns the place drive it while he had a code reader plugged in. He told me it seemed to run fine and cleared the codes and told me to come back if the same problems came back. Well no codes have come back but a problem that's got me more concerned has. My timing chain sounds like it is about to come flying off any minute. First start of the day it makes a loud noise that sounds like the chain has a ton of slack in it and it gets faster as I increase speed. It also makes a lot of noise at the top end of a gear, right before it shifts. I will be taking the car back to the place I bought it from
today to see if they will help me out. Anyone have experience with this problem? I have 213,000 miles on the car.
yesterday i left the car at the shop and today they called and told me i was about a quart low on oil and that was the reason i was hearing the noises. i go to pick it up at 8 tomorrow morning so i guess ill know for sure then.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
