1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
power shifting
Old Oct 18, 2013 | 07:30 AM
I<3 A32's's Avatar
power shifting
How much faster Times can i get if i power shift
Old Oct 18, 2013 | 08:46 AM
Fakie J Farkerton's Avatar
Don't do it; you'll break your phone.
Old Oct 18, 2013 | 09:33 AM
I<3 A32's's Avatar
So. Its. Still broken. Still. Works:>)
Old Oct 18, 2013 | 09:34 AM
I<3 A32's's Avatar
Your. Automatic. Hu??
Old Oct 18, 2013 | 10:27 AM
aackshun's Avatar
He's serious, this one time, he powershifted and cracked his Note 2 screen.
True story brah.
Old Oct 18, 2013 | 01:55 PM
Nope, manual here.
Originally Posted by aackshun
He's serious, this one time, he powershifted and cracked his Note 2 screen. True story brah.
Old Oct 18, 2013 | 02:51 PM
aackshun's Avatar
^ He's trolling you.
He powershifted his auto.
I bet you're like what? How is this possible? Easy.
Unplug your battery for 15 mins to make sure the computers are completely reset.
Once you put the battery back on, start the car and then just put it in neutral, rev it up to 6500, hold it there and drop it into drive, it will program the tranny computer to do that on every shift like a power shift.
For manuals a simple powershift is way easier, just do it without the clutch, if you do it hard and fast enough it'll go right in without crunching.
The grinding just happens from you not being fast enough.
Old Oct 18, 2013 | 03:35 PM
Amerikaner83's Avatar
...if you do it hard and fast enough it'll go right in without crunching
That's what she said
Old Oct 18, 2013 | 10:09 PM
krazy6's Avatar
There's only one way to find out.
Old Oct 19, 2013 | 09:30 AM
Gemner's Avatar
depends on if you've been granny shifting or double clutching like you should
Old Oct 19, 2013 | 10:04 AM
Nealoc187's Avatar
SLOW
i have never tried power shifting. no-lift shifting on the other hand...
Old Oct 19, 2013 | 10:32 AM
chrome91's Avatar
no lift shifting just wreaks havoc on the internals of stickshifts, not worth it at all. some cars like Cobalt SS have computer management for no lift shift that lets you keep the throttle down but when you press the clutch pedal the computer electronically disables throttle until you release the clutch pedal, thats better
Old Oct 19, 2013 | 01:12 PM
ABIGBRAIN's Avatar
Remove the clutch pedal altogether and power shift everywhere you go.
Old Oct 19, 2013 | 02:23 PM
Old Oct 19, 2013 | 11:31 PM
Nealoc187's Avatar
SLOW
how hard no lift shifting is on transmission parts depends on a lot of things: clutch, engine torque, synchro condition, etc. in an underpowered car like most n/a maximas you don't really need to worry much imo.
Old Oct 20, 2013 | 03:52 AM
maxima.713's Avatar
Actually if you race like i used too it will only last about a year with you no lift shifting. Thats only if you use good gear oil lol and i was just making 220whp all motor.
Old Oct 20, 2013 | 07:50 PM
krazy6's Avatar
Go away please.
Old Oct 20, 2013 | 08:03 PM
chrome91's Avatar
i dunno, about a year ago there was a guy in the 5th gen section that said he didnt know why he kept going through transmissions constantly. turned out he was no lift shifting and didnt know it was bad for the trans
Old Oct 21, 2013 | 07:39 AM
Nealoc187's Avatar
SLOW
not true. i've no-lift shifted on every NA 1/4 mile pass i've made since 2002.
Old Oct 21, 2013 | 07:58 AM
Nealoc187's Avatar
SLOW
i'm sure you can find instances of transmissions that were already in poor shape being made worse by no lift shifting (with likely contributing factors of a clutch that is not releasing properly which would definitely increase damage done), just like i can find instances of people who no-lift shift with no observable ill effects since 2002 (i.e. me and every single NA run i've made since 2002 in which is more 1/4 mile passes in manual transmission maximas than probably any other person on this forum).
just to be clear, i'm talking about no lift shifting here, not power shifting. no lift shifting is using the clutch as normal but not letting off the gas when you press in the clutch. power shifting is not even using the clutch, just ramming it out of one gear and into the next. powershifting will do significant damage to your synchros, sleeves, hubs, engagement teeth on the gears in addition to the torque spike the actual gear teeth will see. power shifting is probably 20x worse for your trans than simply not lifting off the gas when you shift.
Old Oct 21, 2013 | 10:33 AM
aackshun's Avatar
Fuu, lets not get started about all of your Drivetrain setups and issues.
Plus you're getting into it with the wrong person about this stuff....
See fuu?
Wait am I in a I<3A32 thread?
* Troll mode engage *
Old Oct 22, 2013 | 06:19 AM
I<3 A32's's Avatar
Well i did the cluch tap one..lol. .4. Slower than a 3.5...
Old Oct 22, 2013 | 06:32 AM
aackshun's Avatar
Clearly there's something wrong w/ the 3.5, to only leave you by a whole half of second in the quarter mile.
Old Oct 22, 2013 | 07:48 AM
I<3 A32's's Avatar
I did a. Quick. Tune. To the. Track i was on a bad knock too. My. Best was a14.7his. Was .14.4. But. He was untuned. But knock was. Good. So idk
Old Oct 22, 2013 | 09:25 AM
aackshun's Avatar
Stock 6mt I assume ran the 14.4, or a lightly modded auto.
BTW, I can't understand your post, I only read like 3 words before my head starts hurting.
Old Oct 22, 2013 | 09:45 AM
I<3 A32's's Avatar
4Th gen 3.5
Old Oct 22, 2013 | 09:47 AM
I<3 A32's's Avatar
4Th gen 3.5
5speed. Schmellys
Old Oct 22, 2013 | 11:02 AM
schmellyfart's Avatar
Allow me to translate using proper grammar. He is talking about racing my car at the track.
The two outer slips are our races. He is car 32.
Old Oct 22, 2013 | 11:10 AM
Soo you rounded my 14.38 up to 14.4 and your 14.79 down to 14.7.
Old Oct 22, 2013 | 11:23 AM
aackshun's Avatar
Well fuhhh, on that first run he looked a lot like the red car back in the day.
Old Oct 22, 2013 | 11:50 AM
I<3 A32's's Avatar
Did that wrong lol
Old Oct 22, 2013 | 12:02 PM
I<3 A32's's Avatar
I just. Remember it was.4. Difference
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
