replacing power steering fluid
Old Oct 21, 2013 | 03:43 PM
GNCMaxima's Avatar
Do I have to use the recommended Nissan dealer power steering fluid Or can I use any other power steering fluid?
Also has anyone ever used the turkey baster method of taking out all the power steering in the reservoir and just replacing the power steering fluid in the reservoir?
Old Oct 21, 2013 | 04:11 PM
lightonthehill's Avatar
I would have no problem using non-Nissan power steering fluid. Just be sure and use exactly the type specified in the owner's manual, and I would use only fresh fluid.
Be very careful to not get even a tiny speck of dirt into the reservoir (clean the outside very carefully before opening the lid).
And I also would have no problem using the 'turkey baster' method of removing the old fluid. Might not get every drop of the old fluid, but then we don't get every drop of the old oil out during oil changes, tranny fluid changes, coolant changes, etc.
Power steering and power steering fluids have changed very little over recent decades, so you should have no trouble.
Old Oct 21, 2013 | 08:56 PM
GNCMaxima's Avatar
Thank you. I appreciate your feedback.
I'll let you know when I need a ride after my car breaks down on the side of the road lol
Old Oct 27, 2013 | 03:14 PM
GNCMaxima's Avatar
Finally got to this and it was easy. Made somewhat of a mess using the turkey baster but yeah lol. A few questions
1. The dealership said the fuild was getting bad but still looked some what new. ..is it bad to change this fuild too often? (If price wasn't an issue to buy fuild 24/7)
2. Also is it okay if I'm Somewhat over the max line? The reservoir has a weird shape too it so its hard to tell exactly
Old Oct 27, 2013 | 03:17 PM
chrome91's Avatar
dont have to change it that often, i bet half the cars on the road today have original power steering fluid in them. little bit over the max line wont hurt as long as its just a bit
should be fine using ATF or any power steering fluid. as far as i know, its only Hondas and old luxury cars like Jaguars that need specific power steering fluid
Old Oct 27, 2013 | 03:25 PM
trailer54's Avatar
1. No, not at all! Just not friendly on the wallet!!
2. I wouldn't worry about it being a little over the line, it won't have any negative effects on it, unless it's extremely overfilled!! Just remember hot fluid expands so it'll rise a little bit when it's get warm!
Old Oct 27, 2013 | 03:30 PM
GNCMaxima's Avatar
Awesome thanks man. Also I wanted to try to do my brake fluid too...Do you know if this method would work with removing the brake fluid with a turkey baster?
I know your suppose to bleed out the brakes but just curious if you can just replace the old fluid in the brake reservoir with new fluid?
Old Oct 27, 2013 | 03:32 PM
GNCMaxima's Avatar
Yeah I guess for the warranty sake I'll keep using nissan recommend fluids lol
Old Oct 27, 2013 | 03:49 PM
trailer54's Avatar
Of course anytime! I wouldn't use the same method for brake fluid, brake fluid is hygroscopic meaning it actually collects water and over time you will actually have small amount of water in your brake fluid which produces a squishy pedal feel, and most importantly lowers the performance of the fluid, example; lowers the boiling point and freezing point of the fluid, also water in the brake fluid can cause parts to rust which is obviously bad!! Definitely recommend a complete flush of the fluid when it comes to brakes!!
Old Oct 27, 2013 | 04:09 PM
GNCMaxima's Avatar
Of course anytime! I wouldn't use the same method for brake fluid, brake fluid is Hydroscopic meaning it actually collects water and over time you will actually have small amount of water in your brake fluid which produces a squishy pedal feel, and most importantly lowers the performance of the fluid, example; lowers the boiling point and freezing point of the fluid, also water in the brake fluid can cause parts to rust which is obviously bad!! Definitely recommend a complete flush of the fluid when it comes to brakes!!
Good info man. When you mean by rusted parts does that include rust to the rotors and brakes etc..?
Old Oct 27, 2013 | 04:31 PM
trailer54's Avatar
Hygroscopic my bad, damn autocorrect... Oh no as in inside of brake lines, master cylinders, calipers!! Just the internal parts of the brakes! It's usually recommended every 2 years or so for brake fluid for that reason! Hope that helps brother!
Old Oct 27, 2013 | 05:15 PM
GNCMaxima's Avatar
So why do they recommend doing changing your brake fuild so early? I can't tell what the color is suppose to be either lol
Old Oct 27, 2013 | 05:19 PM
chrome91's Avatar
brake fluid should be a honey gold or clear, over time it gets to be a darker colour and there can be sludge in the reservoir
as said, you technically are supposed to crack the bleeders and all that when changing the brake fluid, but on my stuff i just use a turkey baster and drain/refill the reservoir. if youre around snow, the bleeders can rust up and seize. sometimes the bleeders then snap off with no effort. if youre in Texas i dont think thats a problem for you lol
Old Oct 27, 2013 | 06:03 PM
Maxgig's Avatar
FYI, if you use the turkey baster method for your reservoir by the time you need new brakes pads on your car (2 or 3 yrs) your brakes will be bled and any old fluid will be removed then.
Old Oct 27, 2013 | 06:27 PM
GNCMaxima's Avatar
Yeah Ive had the car for a year but I drive more then the average person 25k in a year :/
So are you saying I shouldn't replace my brake fluid? I think my rear brakes are going out, but My front ones are still good.
chrome91's Avatar
that depends if you crack the bleeder when pushing in the caliper piston though, ive done hundreds of brake jobs and havent cracked the bleeder once
theres no harm in replacing your brake fluid if you want, i usually replace mine every 3-4 years
Old Oct 27, 2013 | 06:29 PM
GNCMaxima's Avatar
Haha yeah Texas never gets that cold. The fluid looks dark. So there's no harm in a Turkey baster drain and fill of the reservoir? As long as I clean it up and make sure nothing gets in it?
Old Oct 27, 2013 | 06:31 PM
GNCMaxima's Avatar
Where is the bleeder located at? Would hitting a curb at high speeds mess that up?
Old Oct 27, 2013 | 06:32 PM
chrome91's Avatar
you can, but since your bleed screws are probably clean i would eventually do it properly with cracking the bleeders
bleed screw is on the caliper, no way you can damage it on a curb. only problem area with them is they can rust and brake off which is why i dont ever crack them open
look like this
Old Oct 27, 2013 | 06:36 PM
GNCMaxima's Avatar
look like this
So if that screw was rusted or had any fluid on it I would need to replace it asap?
Thank you for the information too
Old Oct 28, 2013 | 06:03 AM
vball_max's Avatar
The turkey baster method wont work on brakes. The power steering system circulates the fluid which mixes the new fluid in the reservoir with the old fluid in the system. The brake system just pushes the fluid one direction towards the caliper so the old fluid would stay in the lines even with new fluid in the reservoir.
Old Oct 28, 2013 | 07:16 AM
Maxgig's Avatar
I'm aware that brake fluid is pushed through the brake system, (this isn't my first car). What I'm suggesting is that he change his old fluid in the reservoir and when his pads are changed he will have cleaner fluid in the system. If he drives like a mad man or does autocrossing of course the fluid would need to be changed totally. But for normal everyday driving the turkey baster will work just fine.
Old Oct 28, 2013 | 07:52 AM
vball_max's Avatar
interesting thought......but i don't think I agree. Even when you push back the piston to change the pads, there will still be old fluid in the caliper, in the line between the main cylinder and and the caliper, and in the main cylinder. When you press the brake pedal for the first time after replacing pads, the new fluid needs to fill the cylinder first, so its likely that the new fluid wont even get into the line. I don't think that the "new" fluid in the cylinder would mix with the old fluid all the way down the line and in the caliper since its essentially a static system.
Personally, I just order 4 speed bleeders for $28.00 which makes it really easy to completely flush the system. That reminds me....I need to order them for my 2012 maxima.
Old Oct 28, 2013 | 05:15 PM
chrome91's Avatar
no not ASAP, it shouldnt leak unless its loose. it will naturally get a bit rusty, but when it rusts enough to seize youre in trouble.
even if it breaks off it wont leak, on my old rusty pickup i replaced a rear brake line and went to bleed it, just put a bit of pressure with a socket and the bleeder snapped right off i think i ended up bleeding it from the line or something, but i never replaced the bleeder and it never leaked
rbuswell
Nov 17, 2016 04:54 AM
vingodine
45
May 21, 2016 12:46 PM
02PearlSE
Oct 7, 2015 02:12 AM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
